G4 ALH: Parts Needed for Timing Belt Replacement
Kuhni
Post18-01-2007, 5:05    Subject: G4 ALH: Parts Needed for Timing Belt Replacement Quote
Hello everyone,
The timing belt on my G4 (manufactured in 2000, ALH engine, all stock components) needs to be replaced soon. Mileage: 177,000 km.
I need the timing belt, tensioner pulley, all idler pulleys, and the water pump. Also, I need the valve cover gasket.
I live here in the USA, and I will be in Germany for 3 weeks in February. I plan to get all the necessary parts while I'm there.
and have it replaced by a qualified colleague. (A VAG-Com diagnostic tool is available).
My questions:
What additional screws, seals, etc. do I need?
'Are there cheaper (better) sources to buy these parts from other than the friendly seller, and what would they cost?'
Here's an online parts retailer where I can find parts; here are the relevant links:
http://replacement.autopartswarehouse.com/parts/autopartswarehouse/wizard.jsp?year=2000&make=VW&model=GOL-D-003&category=All&part=Timing%20Belt%20Kit&dp=true
http://replacement.autopartswarehouse.com/parts/autopartswarehouse/quote.jsp?year=2000&product=G3000-67342&application=000363123&part=Water%20Pump&dp=true
Are the part numbers listed there known?
Unfortunately, I only have about 3 weeks to get the parts, and then there's also Carnival... icon_wink.gif
If you need any further information (e.g., the vehicle identification number), please let me know.
Thank you very much for your help.
....Kuhni!
Translated on 30-09-2026, 16:57.
bafische
Karma: +22 / -0   Thank you, like it!
Post18-01-2007, 21:00    Subject: G4 ALH: Parts Needed for Timing Belt Replacement Quote
Here's the Max version:
Timing belt repair kit with tensioner: 038 198 119 E.
or
Timing belt 038 109 119 M
Idler pulley between the crankshaft and water pump: 038 109 244 M.
Idler pulley bolt between crankshaft and water pump + N 905 969 02
Deflection roller, bottom: 038 109 244 E
Set screw, lower pulley (M8*50) N 101693 03
Washer (8.4 x 15 x 1.6) + N 011 558 11
6-point self-tightening mother nut (Micon_cool.gif + Part number: 900 744 01
Deflection roller, top: 058 109 244.
Guide roller screw (M8*40) + Part number: N 019 531 3
Tension spring 038 109 243 N
Set screw, tensioner pulley (M10A*M8*68-C) N 014 634 1
6-point self-locking mother nut (Micon_cool.gif + N 900 744 01
3 x 6-point screw for fuel injection pump rotor (M8*16) - replace (only for pump rotor 038 130 111 A) + N 903 285 04
or
3 pcs 6-point screw injector pump rotor (M8*16) - (only applicable to 038 130 111 B rotor) + N 907 134 01, but do not necessarily need to be replaced.
Replace serpentine belt (with A/C: 21.36*1660mm) 038 903 137 J.
4 pcs. Allen screws, vibration damper washer, M8*37, part number N 903 396 01.
Engine mounting bracket to body (M8*20) + N 101 559 01
2 pcs. 6-point bolt, engine mounting bracket to body (M10*55-SW16A) + N 105 167 01
2 pcs. 6-point screw for engine mounting bracket to engine mount (M12*1.5*65) - Part number: N 102 096 03.
2 x 6-point screws for motor mount to cylinder head (M10*85 - SW16) - Part number: N 907 124 01.
1 pc. 6-sided screw for motor mount to cylinder head (M10*112 - SW16) N 102 098 01
2 x 6-point screw for gearbox mounting, upper body (M10*55-SW16KL) + N 905 969 02
Bracket for mounting the gearbox to the chassis (M8*20) + N 101 559 01
2 pcs. 6-sided screw, aggregate bracket, gearbox top, to gearbox (M12*1.5*65) - Part number: N 102 096 03.
2 pcs. 6-sided screw for pendulum support to generator carrier (AM8*45) - Part number: N 102 683 02.
1 pc. 6-sided screw for pendulum support to gearbox (M10*30 SW16) N 102 455 03
1 pc. 6-sided screw for pendulum support to gearbox (M10*70 SW16) + N 905 970 01
Dichtung Vakuumpumpe + 038 145 345
(Seal for vacuum pump + 038 145 345)
Water pump 038 121 011 A(X)
3 pcs. Water pump mounting screws + N 909 450 01
Coolant G12.
and of course, "some" tools.
Have fun!
"Luft und Menge müssen stimmen - der Rest ist Physik."
unumstössliches Gesetz in der Dieselmotorenentwicklung
Translated on 30-09-2026, 17:05.
BM
Avatar-BM
Post18-01-2007, 21:50    Subject: G4 ALH: Parts Needed for Timing Belt Replacement Quote
Here's another minimal variant icon_biggrin.gif:
Starting with engine number ALH500001, a different timing belt is used. The repair kit (link) is missing a tensioner pulley.
038 121 011 AX Water pump (replacement) with sealing ring.
038 109 243 N - Tension roller.
058 109 244 Deflection roller
038 109 244 E - Idler pulley.
038 109 244 M Deflection roller.
038 109 119 Timing belt, valid up to ALH, 500,000 km.
028 010 227 E Timing belt, from chassis number ALH 500001.
The following screws need to be replaced:
2 pcs. 6-point screw, engine mounting bracket to body (M10*55-SW16A) + Part No. 105 167 01.
3 pcs 6-point screw fuel injection pump rotor (M8*16) (only for pump rotor 038 130 111 A) + N 903 285 04.
Tensioner roller bolt (M10A*M8*68-C) Part number: 014 634 1.
Washer (8.4*15*1.6) + N 011 558 11
6-point self-locking nut (Micon_cool.gif + part number 900 744 01.
All other screws can be replaced.
Everything together at icon_biggrin.gif approximately 275.- plus VAT.
3B5 AJM
Translated on 30-09-2026, 17:15.
Holger247
Post19-01-2007, 13:39    Subject: G4 ALH: Parts Needed for Timing Belt Replacement Quote
Can't you buy the parts in the USA? Don't they have dealerships there too?
Because packing all those items into the suitcase...
Or is it cheaper here?
The water pump is a replacement part (or at least significantly cheaper as such) - therefore, remove the old pump beforehand, or travel back to Germany later...
GIV - 98 - ALH
Touran 5T 2.0 TDI
Translated on 30-09-2026, 17:19.
Kuhni
Post19-01-2007, 16:14    Subject: G4 ALH: Parts Needed for Timing Belt Replacement Quote
Can't you buy the parts in the USA - aren't there also friendly dealers there, or what?
The prices here at VAG are very high. Just the necessary materials, according to the estimate, amount to...
approximately €400.
Furthermore, you never know if you're getting the right parts, as German vehicle identification numbers are not recognized here.
Regards...
...Kuhni!
Translated on 30-09-2026, 17:20.
BM
Avatar-BM
Post19-01-2007, 21:14    Subject: G4 ALH: Parts Needed for Timing Belt Replacement Quote
Furthermore, you never know if the parts are the right ones, as German vehicle identification numbers are not recognized here.
We've posted the replacement part numbers for you.
I would buy this stuff anyway from the open market, because there are different icon_biggrin.gif available there than with [the company/brand], and you can negotiate discounts. However, you should make sure that you are not sold any junk. You can use the phrase "OE quality" from Conti without any problems. Possibly, you can have the parts assembled individually, because sometimes they are cheaper than in a set.
I would buy the Wapu replacement because of a bad experience with the icon_biggrin.gif.
3B5 AJM
Translated on 30-09-2026, 17:22.
Kuhni
Post20-01-2007, 7:07    Subject: G4 ALH: Parts Needed for Timing Belt Replacement Quote
Okay, first of all, thank you very much for the competent assistance.
I'm going to do some research here to find out where I can...
can obtain speaking parts.
Regards...
...Kuhni!
Translated on 30-09-2026, 17:23.
Kuhni
Post20-01-2007, 18:22    Subject: G4 ALH: Parts Needed for Timing Belt Replacement Quote
Ahem, even though it will cost me Karma points:
Where can I find the engine number on the ALH engine?
Or can this be determined based on the identification number?
The identification number is:
WVWZZZ1JZ1D015159
The vehicle rolled off the assembly line in March 2000.
Best regards & thank you...
...Kuhni!
Translated on 30-09-2026, 17:24.
BM
Avatar-BM
Post20-01-2007, 19:14    Subject: G4 ALH: Parts Needed for Timing Belt Replacement Quote
WHERE can I find the engine number on the ALH?
Normally, there is a sticker on the top cover of the rear differential.
3B5 AJM
Translated on 30-09-2026, 17:25.
Kuhni
Post20-01-2007, 22:10    Subject: G4 ALH: Parts Needed for Timing Belt Replacement Quote
Yep, I checked.
The number is 'ALH 368 420', so the question is, which belt do I need?
also clarified.
Regards...
...Kuhni!
Translated on 30-09-2026, 17:26.
Post20-01-2007, 22:54    Subject: G4 ALH: Parts Needed for Timing Belt Replacement Quote
For the sake of completeness, here is a wanted photo.
If someone finds this thread through a search icon_wink.gif,
 File size:  66.66 KB
 Viewed:  9489 times
mullemaus
Post21-01-2007, 17:09    Subject: G4 ALH: Parts Needed for Timing Belt Replacement Quote
On June 16, 2000, in Tornadorot icon_wink.gif.
Translated on 30-09-2026, 17:27.
Kuhni
Post21-01-2007, 17:18    Subject: G4 ALH: Parts Needed for Timing Belt Replacement Quote
I've checked again, and on March 24, 2000, the...
Operating license granted, certified on June 20, 2000, and on...
The first registration date was July 21, 2000.
Regards...
...Kuhni!
Translated on 30-09-2026, 17:28.
No new posts Serpentine belt (drive belt) replacement for T6 TDI with ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ATF (Automatic Transmission Fluid) replacement in the aut... Troubleshooting & Guides
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts AAT Crankshaft Material Diesel Engine Technology
No new posts Front Spoilers: Materials & Types Transmission, Chassis, Body & Interior
No new posts LLK Absorbent Pads: Material & Guide. Diesel Engine Technology
No new posts ZMS switch to ASZ with ERF Transmission, Chassis, Body & Interior
