bindpe Blaumann
Joined: 08/25/2006 Posts: 203 Karma: +5 / -2 Location: ingolstadt
03-01-2007, 14:22 Subject: Audi A3: Which alternator fits? |
Hello.
Can someone explain to me what the numbers on the Lima actually mean?
The following is written on my LIMA:
0123 515 020
028 903 026 G
120A
If you search for a 120A alternator (Lima) for a VW Golf G3 with the AHU/1Z engine on eBay, you might find alternators with different part numbers that are supposedly compatible. How can I determine if the alternator will fit my engine?
Thank you for your responses. Golf III TDI AHU 402Tkm
Translated on 17-08-2026, 15:18.
mserge Schrauber
Joined: 06/20/2005 Posts: 923 Karma: +6 / -0 Location: Luxemburg
03-01-2007, 14:37 Subject: Lima for Audi A3 AHU: Which one fits? |
bindpe wrote: |
0123 515 020
028 903 026 G
120A
0123 515 020 is the Bosch part number.
028 903 026 G is the VAG part number.
120A is the rated current output, which is 120 amperes.
Perhaps there are Limes that will fit, but if you want to be sure, get the correct one. There's nothing more frustrating than trying to install a Lime later and finding out the pulley isn't the right size, or a hole is slightly different, or something like that. There are so many different types of Limes that you're more likely to find the wrong one than the right one. A4 Avant 2,5 tdi 110kw; AFB; BJ2000
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 17-08-2026, 15:21.
03-01-2007, 15:02 Subject: Audi A3: Which alternator fits? |
Then tell me which ones you found that are supposed to fit.
Ich hatte m.W. eine ... R included.
And while you're at it, replace the freewheel!
Okay, please provide the German text you would like me to translate into English. I will only provide the translation. Transparency, Teamwork
Translated on 17-08-2026, 15:22.
Profile PM Garage |
bindpe Blaumann
10-01-2007, 22:19 Subject: Audi A3: Which alternator fits? |
Translated on 17-08-2026, 15:23.
11-01-2007, 0:02 Subject: Audi A3: Which alternator fits? |
The verb is missing!
What are you planning to do with "these"?
Do they fit and do you want to buy them?
Profile PM Garage |
11-01-2007, 0:06 Subject: Audi A3: Which alternator fits? |
Regarding your links:
Number 1 is not trustworthy because why would he take a photo without showing the part number, which is clearly visible? He's trying to deceive people.
Number 2 doesn't fit.
The 1Z/AHU engine came with part number 028 903 025, which had a current rating of 120 amps.
The climate control air handling unit with model number 120A...026G.
So, choose one  .
Translated on 17-08-2026, 15:25.
Profile PM Garage |
bindpe Blaumann
11-01-2007, 18:45 Subject: Audi A3: Which alternator fits? |
Hello dieselmartin.
Thank you for your quick response.
Why was the 120A Lima (alternator) used in some G3 models even without air conditioning? I've also seen Golf III TDIs with air conditioning that have a 90A alternator. What other factors determine which type of alternator was installed?
What's the best way to determine which Lima bean variety is the right one? Or does only the "026" variety fit?
Best regards, Golf III TDI AHU 402Tkm
Translated on 17-08-2026, 15:26.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1508 Karma: +643 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
25-01-2007, 19:15 Subject: Audi A3: Which alternator fits? |
bindpe wrote: | Hello dieselmartin.
If an auxiliary heating system (Ahk) is installed from the factory, a reinforced radiator, fan, larger battery, and alternator are also included.
You can [url]comparehttp://ecat-online.bosch.de/toc/frame1.htmlthe different LIMA models here; often, there are drawings with dimensions included, which allows you to see whether a particular LIMA fits or not.[/url]
Translated on 17-08-2026, 15:28.
Profile PM Garage |
26-01-2007, 1:11 Subject: Audi A3: Which alternator fits? |
120 A was already the largest Lima in the G3  .
Translated on 17-08-2026, 15:29.
Profile PM Garage |
