Lupo 6X1 MJ 2002: Faulty Heating Control System (Solution)
Michael II
Post01-01-2003, 16:26    Subject: Lupo 6X1 MJ 2002: Faulty Heating Control System Quote
Heating regulation without function.
Cause:
The cable from the heating unit is not properly routed. This incorrect routing can impede or even block the movement of the rotary switches.
Defroster flap linkage: loose, detached, pinched, strained, misaligned.
Mounting clips for hinge rods are loose and not assembled.
Solution:
Spare part. Check the routing of the cable for the heating device and, if necessary, reposition it correctly.
Trains - Installation and adjustment of heating and air conditioning systems.
Tschüss
Michael II
Translated on 05-10-2026, 20:43.
Ratings - Lupo 6X1 MJ 2002: Faulty Heating Control System
No new posts Lupo 6X1 MJ 2002: Horn Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Window lifter not functioning Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lupo 6X1 MJ 2002: Clicking Noise Diagnosis Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Correct oil for AWX engine, year 2002, without DPF Diesel Engine Technology
No new posts ASR Not Working: Troubleshooting & Fixes Transmission, Chassis, Body & Interior
No new posts ESP not working On-Board Diagnostics (OBD)
No new posts Fresh air blowers without function On-Board Diagnostics (OBD)
