Doku Lupo 6X1 MJ 2001, Whistling noise at the doors (Solution)
Michael II
Post01-01-2003, 16:39    Subject: Doku Lupo 6X1 MJ 2001, Whistling noise at the doors Quote
High-frequency whistling noise coming from the doors.
Between 70 - 110 km/h, in the area of the side mirrors.
Cause:
There is a large gap between the window frame and the door glass in the area of the triangular section at the top.
Solution:
Remove the cover, starting from the top and gently prying it loose to prevent the retaining clips on the cover from breaking.
Loosen the fitting on the mirror base until the triangular piece at the top can be tilted slightly.
Insert the butyl cord into the darkly marked area.
Secure the mirror base and remove any protruding butyl rubber.
The butyl strip creates pressure on the window frame, ensuring that the gap between the window frame and the door panel is sealed when the screws are tightened.
Tschüss
Michael II
Ratings - Doku Lupo 6X1 MJ 2001, Whistling noise at the doors
No new posts Lupo Door Problems: 6X1 MJ 2002 Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Lupo 6X1 MJ 2001, Door panel noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Lupo 6X1 MJ 2001, Dashboard Noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts GTI 2.0 BWA whistling noise Gasoline Engine Technology
No new posts Audi A3 Whistle Noise: BLS Engine, 2006 Diesel Engine Technology
No new posts Door Knocks: Secrets & Hidden Meanings Transmission, Chassis, Body & Interior
No new posts Creaking Doors, A3 Two-Door Model... Transmission, Chassis, Body & Interior
