07-02-2007, 16:33 Subject: Software Version 038 906 012 AT - Change |
Hi.
Am I correct in assuming that the behavior of a 038 906 012 AT can only be changed through a "rebuild"? Is it not yet possible to modify it through flashing with the EDC 15P?
The device is installed in the Leon and is quite temperamental when the outside temperature is around 4 degrees Celsius.
It doesn't glow yet, and the car starts up like an old Lanz tractor.
"It's okay above it - and below it too (because then it will glow)."
The plausibility check of the temperature sensors showed identical values for all three sensors, down to the hundredth of a degree.
Translated on 18-09-2026, 21:49.
Profile PM Garage |
Rudi Guest
07-02-2007, 16:38 Subject: Software Version 038 906 012 AT - Change |
Hi Martin,
The 012AT is already flashable via diagnostics.
Rudi
Translated on 18-09-2026, 21:50.
07-02-2007, 16:43 Subject: Software Version 038 906 012 AT - Change |
OHOH,
I have some new plans... The Leon always seems to have problems, and it's very important to me that the car runs well.
Profile PM Garage |
07-02-2007, 19:01 Subject: Software Version Update: 038 906 012 AT |
dieselmartin wrote: | 038 906 012 AT . . . This thing is installed in the Leon and is quite temperamental when the outside temperature is around 4 degrees Celsius.
It doesn't glow yet, and the car starts up like an old Lanz tractor. |
Hi Martin,
The software indicates a preheating time of approximately 2 seconds when the water temperature is 4°C.
Have you ever tried it using adaptation? Channel 12 should be the preheating time, if I recall correctly?
Quote: | | The temperature sensor plausibility check showed identical values for all three sensors, down to the hundredth of a degree. |
No wonder the resolution of the diagnostic image is usually 0.9K.
Therefore, you can be reasonably sure that no one deviates from the others by more than 0.9K.
Translated on 18-09-2026, 21:52.
Profile PM Garage |
vagtuning Guest
07-02-2007, 20:03 Subject: Software Version 038 906 012 AT - Change |
Hi Martin,
Best regards, Rudi
'Oh? And where can one find data sets for that?'
Seat is acting like it doesn't exist.
Or is the statement solely reduced to tuning measures?
Translated on 18-09-2026, 21:53.
Rudi Guest
07-02-2007, 20:19 Subject: Software Version 038 906 012 AT - Change |
Hi Martin,
Best regards, Rudi
The statement initially referred to 'soldering or flashing'.
What kind of data formats would you prefer?
Which Seat model solves the problem?
Translated on 18-09-2026, 21:54.
vagtuning Guest
07-02-2007, 20:24 Subject: Software Version 038 906 012 AT - Change |
I've always been curious about which devices are actually 'updated' via a tester.
Translated on 18-09-2026, 21:55.
Jochen_145 Guest
07-02-2007, 20:25 Subject: Software Version 038 906 012 AT - Change |
Oh? And where can one find data sets for that??
Hello.
If I understand correctly, this is about two different things.
Rudi is referring to the basic flashing of the MSG (Modular Service Unit) via the OBD (On-Board Diagnostics) interface. This is possible with Seat vehicles using the aforementioned MSG and the appropriate tools.
To the best of my knowledge, there is no software update available from Seat.
Seat hasn't made any changes to the software in recent years. At least, that's what most tuners and my local Seat dealer know.
Modifications to the dataset by Martin will likely only be possible through a tuner or through individual initiative using the tools of a tuner.
Best regards, Jochen.
Translated on 18-09-2026, 21:56.
vagtuning Guest
07-02-2007, 20:33 Subject: Software Version 038 906 012 AT - Change |
That's exactly the question I'd be interested in: which ones exist, and whether they could potentially be updated.
It's clear that this is about either specific tools or a tuner.
But exactly that kind of information 'from Seat' doesn't exist, which surprises me.
'There must be some kind of information available somewhere; I was just checking to see if I might have missed something, because I haven't seen any updates from Seat. I know that VW has released some updates, but I'm not aware of anything similar from Seat or Skoda.'
I thought I would learn something from this  .
Translated on 18-09-2026, 21:58.
08-02-2007, 9:36 Subject: Software Version 038 906 012 AT - Change |
Quote: | | Have you ever tried it using adaptation? Channel 12 should be the preheating time, if I recall correctly? |
Hi Ulf,
I tried to increase the initial amount. The new value was accepted, but nothing changed when I started the process.
The problem is that the attempts after a "mare" attempt often go much better, and you don't know if the solution was found or if he just resigned himself to starting  .
"A higher preheating time would be another alternative, although I thought it wouldn't actually heat up at 4-5 degrees - at least that's what the display seems to indicate. The temperature sensors (GSK) are new and have been re-calibrated."
Thank you.
Translated on 18-09-2026, 22:00.
Profile PM Garage |
08-02-2007, 9:38 Subject: Software Version: Change 038 906 012 AT |
dieselmartin wrote: | The device is installed in the Leon and is quite temperamental when the outside temperature is around 4 degrees Celsius.
"Addendum:"
The simplest solution is likely to wait 2 seconds after the heating element turns off, but before starting, if the temperature is below approximately 10°C.
The spark plugs continue to receive voltage for a while longer (which can be easily observed using an LED connected to the glow relay output), presumably to give even "slow starters" a chance to start the engine with properly heated spark plugs.
Quote: | | A higher heating time would be another alternative, although I thought it wouldn't even heat up if it's 4-5 degrees - at least that's what the display seems to indicate. |
Sure: the glow plug usually activates briefly for a self-check. As long as the preheating time, according to the software, isn't significantly longer, it appears as if it's not glowing at all.
Translated on 18-09-2026, 22:02.
Profile PM Garage |
Rudi Guest
08-02-2007, 11:45 Subject: Software Version 038 906 012 AT - Change |
Apart from the interpolation strategy (stepwise?!  ),
Does the Leon start to warm up later than the Polo (Polo at the top, Leon at the bottom)?
| Description: |
| File size: |
6.18 KB |
| Viewed: |
1503 times |
Translated on 18-09-2026, 22:04.
08-02-2007, 12:15 Subject: Software Version 038 906 012 AT - Change |
Rudi wrote: | Apart from the interpolation strategy (step-like?! ),
Does the Leon start to warm up later than the Polo (Polo at the top, Leon at the bottom)? |
Okay.
However, since the Leon doesn't preheat at all below 10°C (my observations of the glow LED indicate a linear interpolation; the post-glow time is certainly linearly interpolated between the reference points), its glow plugs are essentially on up to 9.9°C - and presumably, the "quick-start follow-up time" will also be present, which can be exploited to improve cold starts.
Translated on 18-09-2026, 22:05.
Profile PM Garage |
