Preheat Light Not On? Troubleshooting Guide.
janxl
Post11-02-2007, 18:34    Subject: Preheat Light Not On? Troubleshooting Guide. Quote
I converted my Golf 3 TDI 1Z to an AFN engine, including installing Climatronic. Everything is wired up, but when I turn the ignition on, the glow plug light doesn't come on, and the engine cranks but doesn't start. I replaced the immobilizer from the donor vehicle, including the ignition cylinder and the transponder in the key. What else could be the problem?
Sure, no problem. Here's the translation:
"Thanks in advance... Jan"
Translated on 01-09-2026, 2:43.
vagtuning
Post11-02-2007, 22:36    Subject: Preheat Light Not On? Troubleshooting Guide. Quote
Since the engine control unit (ECU) has a fault memory, I would check it to see if there are any stored error codes. Otherwise, I would go through the few available data blocks and check the values for plausibility.
Translated on 01-09-2026, 2:44.
Rudi
Post12-02-2007, 8:23    Subject: Preheat Light Not On? Troubleshooting Guide. Quote
As long as it doesn't start at all, it's not the WFS.
It sounds more like the MSTG isn't being supplied with power or isn't starting up because someone...
someone tampered with the PROMs, because the system light should also come on when the WFS is active.
Diagnosis can still be helpful. Either access is not possible, or...
( icon_arrow.gif A power supply, wiring, or software issue) or there are errors stored.
Rudi
No new posts Document 1J, ESP Control indicator is lit up. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J ABS Light: Repair Guide & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J up to week 38/2000, ABS control light is on. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI: Glow Plug Light On, Engine Won't Start On-Board Diagnostics (OBD)
No new posts ABS Light On: Window & Turn Signal Problems Diesel Engine Technology
No new posts Preheating indicator Diesel Engine Technology
No new posts Glow plug indicator function Electrical Systems, Vehicle Electronics, Multimedia
