Audi A3 TDI: Cold Start Problems After Timing Belt Change
joeol77
Post04-01-2003, 14:59    Subject: Audi A3 TDI: Cold Start Problems After Timing Belt Change Quote
I am facing a problem.
Since my Audi A3 TDI 110PS had its timing belt changed (along with the 90,000 km service), I've noticed that it's reluctant to start after being idle for a longer period (e.g., overnight). I usually need 2-3 attempts. When it does start, it produces a lot of smoke, and it smells strongly of diesel exhaust.
The problem is not dependent on the outside temperature.
However, I've noticed that it starts a little better if I repeat the pre-glow process 2-3 times (by turning the key) and then start the engine.
I hope someone can offer me some advice, because I'm completely at a loss.
Thank you very much, and best regards.
Joeol77
Translated on 03-10-2026, 14:22.
Post04-01-2003, 18:18    Subject: Audi A3 TDI: Cold Start Problems After Timing Belt Change Quote
Hi.
It seems the workshop probably messed something up, meaning the valve timing and/or the pump settings are likely incorrect now.
If you can't do anything yourself on the car, complain about the work (good luck with that icon_sad.gif).
Otherwise, please refer to the technical article on pump settings.
Translated on 03-10-2026, 14:23.
Markus H.
Post04-01-2003, 22:37    Subject: Audi A3 TDI: Cold Start Problems After Timing Belt Change Quote
Yeah, the injection start time isn't right.
I'm currently experiencing the same issue with the AAT.
Whether the pump is misaligned, they should at least be able to tell you that for free...
It costs 75 euros icon_eek.gif at AAT to have it done, but I'm still getting it done because I don't want to mess with the timing belt.
Translated on 03-10-2026, 14:24.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Cold Start Issues: AEL R5 Fine Tuning Diesel Engine Technology
No new posts Audi 80 B4: Cold Start & Idle Control Issues Diesel Engine Technology
No new posts AFN Cold Start Issues & Engine Control Unit Replacement On-Board Diagnostics (OBD)
No new posts A6 AAT cold start problems, the umpteenth... Diesel Engine Technology
