kottan-ermittelt Guest
16-01-2007, 9:30 Subject: Whining transmission on A4 2.5 TDI, 12/99 |
Hello.
'Recently, my A4's transmission (2.5 TDI, 12/99, 150,000 km) has been making a howling noise.' It's not audible during acceleration or when driving at a constant speed, but only when releasing the gas pedal, specifically when the clutch is engaged, and starting around 90 km/h.
What could be the cause? How do I get a diagnosis?
Thank you for any advice!
Steffen.
16-01-2007, 14:01 Subject: Whining transmission on A4 2.5 TDI, 12/99 |
That's probably what they call 'putting things off.'
BM Profi-Schrauber
Joined: 12/07/2005 Posts: 1857 Karma: +8 / -0 Location: Nähe Düsseldorf
16-01-2007, 16:35 Subject: Whining transmission on A4 2.5 TDI, 12/99 |
Quote: | | What could be the cause? How do I get a diagnosis? |
By first providing useful information  .
- Automatic / Manual transmission? Gearbox identification code?
- In which gear does the noise occur?
- temperature-dependent?
- Description of the sound.
- Is the transmission leaking oil, or is the oil level okay?
- etc.
3B5 AJM
16-01-2007, 18:02 Subject: Whining transmission on A4 2.5 TDI, 12/99 |
I am trying to be more precise  .
- 6-speed manual transmission, transmission code DQS.
- In which stage of the process does the noise occur: 4, 5, and 6?
- equally effective with a cold engine and a warm engine.
- is definitely a high-frequency sound, singing.
- The transmission is not leaking any oil, and the oil level is okay.
- The transmission oil was changed yesterday - no change.
16-01-2007, 22:27 Subject: Whining transmission on A4 2.5 TDI, 12/99 |
I recorded it with my phone, it's a load change in 4th gear, between 2000 and 3000 rpm. Unfortunately, I can't upload it as an MP3, so I renamed the file from 'sound.mp3' to 'sound.jpg'.
| Description: |
| von sound.mp3 nach sound.jpg umbenannt |
| File size: |
339.75 KB |
| Viewed: |
3696 times |
Herr Antje Schrauber
Joined: 01/18/2006 Posts: 1547 Karma: +7 / -0 Location: Nahe Tübingen
17-01-2007, 7:09 Subject: Whining transmission on A4 2.5 TDI, 12/99 |
I'm guessing it's either the transmission (specifically, the clutch) or the differential. For both, the transmission needs to be removed, so I'll start by seeing if you can get any other advice. Unfortunately, I don't have any  .
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
R.M. Schrauber
Joined: 06/15/2004 Posts: 389 Karma: +14 / -0 Location: DD
20-01-2007, 10:30 Subject: Whining transmission on A4 2.5 TDI, 12/99 |
"Also, I also had a differential issue on my 35i. After a drive, check the transmission where the driveshafts come out, or the driveshafts themselves." One of the drives was cold (normal), while the other was extremely hot.
Hi!
15-02-2007, 13:48 Subject: Whining transmission on A4 2.5 TDI, 12/99 |
It was a bearing in the transmission. I had it fixed for 1000 [currency]. Thank you for the tips!
Helau.
15-02-2007, 13:57 Subject: Whining transmission on A4 2.5 TDI, 12/99 |
kottan-ermittelt wrote: | | a bearing in the transmission |
Thank you for the feedback. Hopefully, you'll have some peace and quiet for a while now.
kottan-ermittelt wrote: | | I had it made for 1000. |
Only the stock items, or all items? Does the price include installation and removal?
Aktuell:
27-02-2007, 9:48 Subject: Whining transmission on A4 2.5 TDI, 12/99 |
'1000 for everything, including installation and removal. I don't know if all the bearings were replaced or just the defective one. In any case, all the wheels had to be removed from the shaft (they had to be shrunk-fitted), which was quite complicated. It was done by a professional, and it's working perfectly again.'
