Leistungsverlust im unteren Drehzahlbereich1,9 TDI-PD 130 PS | Posts 48+
Go to page: Previous  1, 2, 3, 4
Post06-03-2007, 22:17    Subject: Quote
matt wrote:
Komisch finde ich den LMM-Einbruch bei 2000 min^-1, wie man in der ersten xls-Datei sehr schön sehen kann.
That actually corresponds quite well to the decrease in LD (lambda value) at the same engine speed: less LD means less air mass, which is perfectly logical.
Many TDIs exhibit this low-RPM "stuttering" or hesitation when accelerating at full load, and it's likely not a sign of a defect (mine does too).
Translated on 08-07-2026, 3:18.
matt
Post07-03-2007, 1:26    Subject: Quote
Yes, you're absolutely right! Unfortunately, I lost the log data from a similar test that used a diode, due to messing around with the CSV file. It would have been great to see what was happening there. I'll try to visualize that data again using Excel later.
I'm curious to see what comes out of a new LLM in terms of soot reduction and other factors.
Best regards, Matthias.
Translated on 08-07-2026, 3:19.
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts div. Golf 1J TDI and Gasoline, gradual loss of power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts V6 TDI: Reduced Power at Low RPM Diesel Engine Technology
No new posts FORD 1.8 TD - Power loss in the low-speed range Diesel Engine Technology
No new posts Power loss at low RPM, Bora ASZ Diesel Engine Technology
No new posts Engine Performance Issues: Low RPM Problems Diesel Engine Technology
