Golf4, ALH engine, Highline trim, 188,000 km, all original.
Hello everyone,
'I adjusted the pump setting slightly about two weeks ago. Before that, according to the TDI graph, it was a bit below the blue center line. Now it's a little higher, just above the ideal line.'
I did that to improve the warm-up performance.
Interestingly, at the same time, MFA is also calculating consumption differently.
The consumption has decreased slightly (calculated from 5.2 to 5.0).
However, the MFA reading shows 10% less, at 4.6-4.7.
That really shouldn't be the case.
I'm starting to think that the pump is quite worn out.
Could that indicate something?
