poppel Blaumann
04-03-2007, 18:42 Subject: Central Locking: How to Make Your Horn Work |
Hello, I would like my car alarm to sound a beep when I lock or unlock it.
I configured it as follows:
-> Channel 06 (Unlock Horn)
The unlocking is confirmed with a short beep (0 = off; 1 = on).
According to the German legislature, it is not approved.
-> Channel 07 (Locking horn)
The locking is confirmed with a short beep (0 = off; 1 = on).
So, both are set to the value 1!
He's not honking.
VW T5, first registration 02/27/2007, Multivan, 2.5 TDI, 128 kW, automatic transmission.
Does anyone have any ideas?
Translated on 06-09-2026, 18:57.
matt Guest
04-03-2007, 18:54 Subject: Central Locking: How to Make Your Horn Work |
This can only be done with the factory alarm system.
A diode is installed on the cable running from the comfort control unit to the turn signal relay, and a chirper from Conrad, costing only a few euros, is connected before the diode.
If the turn signal activation in your vehicle is controlled via CAN bus, then this simple solution will not work.
Best regards, Matthias.
Translated on 06-09-2026, 18:59.
myfisch Guest
04-03-2007, 22:07 Subject: Central Locking: How to Make Your Horn Work |
If there's a DWA (device for water damage), the horn might also be submerged.
dieter Profi-Schrauber
Joined: 01/27/2003 Posts: 270 Karma: +13 / -0 Location: LK Uelzen
05-03-2007, 13:43 Subject: Car Alarm: Central Locking Activation |
poppel wrote: |
He's not honking.
Luckily!
What the hell are you talking about? Do you really think your neighbors care if your car alarm is on when you come home at night?
How can someone be so inconsiderate, constantly bothering their fellow citizens for such a silly show?
Greetings,
dieter T3 syncro 16 AFN
Translated on 06-09-2026, 19:00.
myfisch Guest
05-03-2007, 15:52 Subject: Central Locking: How to Make Your Horn Work |
That's not really very loud at all. If the neighbor is woken up by someone banging on the door, at least he knows that if he has to leave his neighbor's wife!
Tom.
Translated on 06-09-2026, 19:01.
matthiasTDI96 Profi-Schrauber
05-03-2007, 16:56 Subject: Central Locking: How to Make Your Horn Work |
And another neon tube under the bus...
It's good that I don't understand some problems!
matt Guest
06-03-2007, 0:12 Subject: Central Locking: How to Make Your Horn Work |
@dieter
The DWA horn emits a subtle chirping sound.
06-03-2007, 9:58 Subject: Central Locking: How to Make Your Horn Work |
It is still a completely unnecessary annoyance and is therefore not permitted.
If someone feels the need to boost their ego with such nonsense, they should probably consider seeking therapy.
Greetings,
Translated on 06-09-2026, 19:02.
Ibi6L-ASZ Blaumann
Joined: 07/20/2005 Posts: 56 Karma: +3 / -0 Location: Bochum 2004 Seat Ibiza Free account, no CAN development support
06-03-2007, 13:14 Subject: Central Locking: How to Make Your Horn Work |
It might be different with the Multivan, but with the Ibiza, the alarm is so incredibly loud that it's really unpleasant. People can still hear it and turn around from 20 meters away.
My friendly technician had kindly activated it for me when I asked him to disable the individual locking feature  .
Well, one day later, I ordered my VAG-COM  . BMW 123d Coupe
Profile PM Garage |
myfisch Guest
07-03-2007, 1:00 Subject: Central Locking: How to Make Your Horn Work |
It's quite subtle on the Golf IV!
Tom (no horn!)
Translated on 06-09-2026, 19:03.
Arne Guest
07-03-2007, 10:53 Subject: Central Locking: How to Make Your Horn Work |
My A8 also beeps very briefly. It's not the horn, but a beeping sound coming from the trunk. I find it relatively useful because the sound only appears when all the doors are closed. If the car is locked and a door isn't properly closed, there's no sound. My car doesn't have a turn signal indicator yet, and the vacuum pump in the trunk is very quiet, so I would have to look at the buttons anyway to know if it's closed, even without the sound. It's always been like this, and it's never bothered me. When unlocking, it's silent.
Arne.
Translated on 06-09-2026, 19:04.
Maxx1278 Blaumann
![Avatar-Maxx1278]()
Joined: 03/02/2006 Posts: 233 Karma: +1 / -0 Location: St.Johann/Pg.
07-03-2007, 11:28 Subject: Central Locking: How to Make Your Horn Work |
I activated the horn to sound when the car alarm is triggered in my Golf V.
That's a very short beep, and on the Golf V's alarm system, a siren is used instead of a horn.
I also set it up so that I can disable it in MFA+ if needed.
Best regards.
Maxx.
Translated on 06-09-2026, 19:05.
Hati Guest
07-03-2007, 19:12 Subject: Central Locking: How to Make Your Horn Work |
The Golf IV is quite subtle!
Tom (no honking!)
'...but in my case (with my G IV), the central ventilation system is so loud that it would probably drown out any other sounds, like honking, chirping, or whatever. Every time I hear it, I think someone is shooting at me.'
Even in a large parking lot, I can still hear my car's central locking system closing from a distance of 10 meters away.
I don't need that.
Translated on 06-09-2026, 19:06.
Bertil Profi-Schrauber
07-03-2007, 20:00 Subject: Central Locking: How to Make Your Horn Work |
Hati wrote: | ...
... but for that, the central ventilation system (at least in my G IV) is so loud that it would probably even drown out the horn. |
Mine is also very loud. No one has commented on the honking, but they have commented on the sounds of the central locking motor.  Gruß Bertil
Translated on 06-09-2026, 19:07.
