eike Guest
02-05-2002, 9:40 Subject: Golf 4: Hidden MFA & Climatronic Menus |
Hi everyone,
I've heard several times about additional display options/menus for MFA (Multi-Factor Authentication). Unfortunately, I haven't been able to find any information on how to enable them. Does anyone know how to do it?
The same applies to the Climatronic system. There are two diagnostic menus that can be activated by pressing a specific key combination. This works reliably. Does anyone have a list explaining the meaning of the data that can be accessed?
Stimmt es, daß man über die Climatronic den Fehlerspeicher des Steuergerätes auslesen kann? Theoretisch müßte das funktionieren, da die Geräte über einen Bus miteinander verbunden sind (Aussage meiner Werkstatt). Die wissen aber nicht, wie. Wozu auch, die haben ja ihr Diagnosegerät. Hat jemSure, here is the translation of the text from German to English:
'and Infos dazu?'
'and information about it?'
Is there anything preventing us from integrating this kind of information directly into this website (e.g., in a 'Tips & Tricks' section for care and crafting)?
Stay cheerful!
Eike.
Translated on 12-10-2026, 3:23.
Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
02-05-2002, 10:08 Subject: SEO-Optimized: "Best German SEO Agency | Eike" |
Just search on Google or a similar search engine for "diagnosis" and "climate control."
You will find some pages that describe the meanings of the displayed values. However, I don't want to include those tables in the "Tips & Tricks" section, as they would ultimately be just duplicates of the information found on other websites. All I would be doing is copying the tables.
Translated on 12-10-2026, 3:24.
Profile PM WWW Garage |
HGK Guest
02-05-2002, 22:06 Subject: Golf 4: Hidden MFA & Climatronic Menus |
I found this table in another forum, but I can't remember where. It works for my Golf IV, though.
It's easy to try: just make it colder, reduce the fan speed, and press the 'eco' button.
Use the functions to adjust the temperature, either warmer or colder.
Climate Codes Part II.
Golf IV, control unit code # 3B1907044B, with a total of 45 channels (including the zero channel).
For the flaps, 0 means closed, and 255 means fully open. If there's a (+/-) symbol after the value, you can control it with the fan, and you'll hear/feel a difference.
00 = Total value, 0 = maximum cooling, 255 = maximum heating.
01 = Interior temperature sensor (located on the control panel of the Climatronic system).
02 = Average solar radiation index.
03 = Solar irradiance index in mW/cm².
04 = Outside temperature, bumper (average/delayed).
05 = Current value: Outside temperature, bumper.
06 = Temp. Fresh air intake duct (?)
07 = Temp. Foot stirrers.
08 = Temperature sensor, but no sensor connected.
09 = Blower control (can be controlled with a blower motor using +/-).
10 = Fan speed.
11 = Temperature control valve (0 = maximum warm, 255 = maximum cold), (+/-).
12 = Upper body exercise (+/-)
13 = Air flap (open/close) (+/-)
14 = Wiper motor for windshield (+/-)
15 = Time since engine start in seconds.
16 = Speed (digital speedometer)
17 = ?
18 = is usually 0. Occasionally, I've seen 65, 68, and 69 (when it's very, very hot). I have no idea what it means.
19 = ?
20 = Deviation from the rule, range 0-100.
21 = Deviation from the rule, heating only allowed between 0 and 100.
22 = ?
23 = ? temp id. with #7 ?!
24 = current temperature setting for the heating flap or a temperature that can be adjusted with a +/- setting. I assume it's the maximum allowed temperature for item 23 or item 7, to prevent burns to the feet.
25 = ?
26 = value, temperature, valve.
27 = ?
28 = ?
29 = value of footwell?
30 = ?
31 = ?
32 = value of recirculation flap.
33 = ?
34 = ?
35 = value of windshield washer nozzle (defroster nozzle).
36 = ?
37 = ?
Starting at age 38, certain values become fixed.
38 = 10
39 equals 0.
40 = -51°C
41 = 0
42 equals 3.
43 = 2
44 = 0
'Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein perfekter Tag für einen Spaziergang im Park.'
'The sun is shining brightly, and the birds are chirping happily. It's a perfect day for a walk in the park.'
Translated on 12-10-2026, 3:30.
oern Guest
11-05-2002, 18:16 Subject: Golf 4: Hidden MFA & Climatronic Menus |
Hey!
Okay, here's how it worked on my older Golf models: Hold down the MFA (Multi-Function Display) button, turn the ignition on, turn the ignition off, then turn the ignition on again. On the older model, it was really cool because it displayed all sorts of information. On the newer model, it only switches between the instantaneous (not average) fuel consumption, oil temperature, and outside temperature. Try it out. Unfortunately, I don't know how to do it on the Tronic model... Let me know if it works for you.
Translated on 12-10-2026, 3:35.
eike Guest
13-05-2002, 7:06 Subject: MFA Menu & Climatronic Dashboard: How-to Guide |
I've heard/read various things and tried different approaches, but so far without success. Which button/switch on the MFA are you referring to? My MFA has three (reset, menu up, and menu down).
'Does anyone have any experience with the accuracy of the speed display in the Climatronic system? If it's accurate, my Golf4 TDI with a 90hp engine should reach a maximum of 188 km/h according to the speedometer, but it only actually reaches 174 km/h.'
Stay cheerful.
Eike.
Translated on 12-10-2026, 3:36.
oern Guest
13-05-2002, 13:57 Subject: Golf 4: Hidden MFA & Climatronic Menus |
'Okay, it seems the problem is that the two- and three-cylinder Golf models only have one menu button. You have to press and hold that button, then turn the ignition on, turn it off, and turn it on again, and then it should work. You can also try using the 'menu up' or 'menu down' buttons.'
Translated on 12-10-2026, 3:37.
SirBiBi Guest
13-05-2002, 21:31 Subject: Golf 4: Hidden MFA & Climatronic Menus |
However, I only ever find information about the tricks that work with the MFA (Multifunction Display) in the Golf 2 and 3 models.
My '98 Passat has reset, menu up, and menu down buttons.
Does anyone know if there are any hidden ads there?
I know how to reset the inspection interval and the oil service reminder.
Best, Björn.
Translated on 12-10-2026, 3:38.
oern Guest
14-05-2002, 20:08 Subject: Golf 4: Hidden MFA & Climatronic Menus |
@siribiri
Really? How do you reset it?
Translated on 12-10-2026, 3:39.
SirBiBi Guest
14-05-2002, 22:23 Subject: Golf 4: Hidden MFA & Climatronic Menus |
It's even in the manual! *wonder*
Hold down the odometer reset button, turn the ignition on (release the button), and you should then see 'INSP' or 'OEL' appear.
If you press and hold the reset button for a slightly longer time (about 2 seconds), the value should reset.
To reset each setting, you need to turn the left switch (used for setting the time) to the right or left. Then, press the reset button again, and this value will also be reset.
You can try it out. If it doesn't work, check your user manual.
Best, Björn.
Translated on 12-10-2026, 3:40.
