Audi A3 Cracking Noise B-Pillar (8L 1996-2001) (Solution)
Michael II
Post08-01-2003, 14:40    Subject: Audi A3 Cracking Noise B-Pillar (8L 1996-2001) Quote
Cracking or creaking noises from the B-pillar, lower left/right side, when driving on uneven surfaces, and during acceleration and deceleration/load changes (only applies to 5-door models).
Cause:
The reinforcing plate in the rocker panel/sill is rubbing against the inner rear edge of the B-pillar, causing creaking or popping noises.
Solution:
- Remove the door sill trim.
- Drill a hole in the outer lower support panel.
With a spacing of a = 10 mm and a diameter of 10 mm.
- Weld the inner B-pillar, the inner reinforcing plate of the lower crossmember, and the outer lower crossmember together using a shielded gas welding process.
- Restore corrosion protection.
Tschüss
Michael II
Translated on 21-09-2026, 1:58.
Ratings - Audi A3 Cracking Noise B-Pillar (8L 1996-2001)
No new posts Document A4 8D, production date up to 10/1999, dents on t... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Doku: Clicking Noises (Up to KW 16/98) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8L Seat Creaking Noise Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts How do you loosen the hinge screws on the A-pillar? Transmission, Chassis, Body & Interior
No new posts Audi 100 C4: Water in A-Pillar - Fix It! Transmission, Chassis, Body & Interior
No new posts Golf 4 leaking at the A-pillar (4-door) Transmission, Chassis, Body & Interior
No new posts What is the purpose of an ABE (General Operating Permit) ... Transmission, Chassis, Body & Interior
