Dents or depressions on the outer surface of the D-pillar.
Cause:
Incorrectly set mixing parameters for the insulation foam in the D-pillar result in shrinkage of the insulation foam. The insulation foam, which is attached to the outer skin of the D-pillar, is integrated into the structure.
Solution:
Preheat the area to be bonded using a hot air gun (approximately 450°C outlet temperature) mounted on a D-pillar, keeping a distance of approximately 5 cm for 2-3 minutes. The indentations will naturally disappear due to the effect of heat.
Sure, here's the translation:
"Note:"
Choose a temperature that is not too high, as this could cause discoloration in the topcoat. TschĂŒss
Michael II
