harj Guest
04-02-2007, 19:44 Subject: Clutch Not Disengaging: Causes & Fixes |
In a 2.5L TDI Audi A4, what might be defective in this case?
The master cylinder in the footwell is sealed, but the other one can probably only be checked after removing the transmission?
What is the expected cost of such a renovation project? Does the engine need to be removed?
Sepp.
I'll probably hand in the part for repair after this, and I'm still a bit unsure about what to get as a replacement.
javascript:emoticon('  ')
Rolling Eyes
Translated on 31-10-2026, 5:54.
Herr Antje Schrauber
Joined: 01/18/2006 Posts: 1547 Karma: +7 / -0 Location: Nahe Tübingen
05-02-2007, 7:43 Subject: Clutch Not Disengaging: Causes & Fixes |
As far as I know, the clutch slave cylinder on the transmission can be removed while the transmission is still installed (you can simply follow the clutch line). I once removed it to inspect it (check the internal pump and try to push the cylinder in). You won't lose any brake fluid, right? Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 31-10-2026, 5:55.
matthiasTDI96 Profi-Schrauber
05-02-2007, 9:42 Subject: Clutch Not Disengaging: Causes & Fixes |
First, you should bleed the clutch, as it can be done with the system installed and is relatively simple compared to everything else. If there's a lack of brake fluid (be aware that the clutch draws its fluid from the rear section of the reservoir, which is separated), you should check under the transmission to see if there's a leak there or along the way. Does the pedal still have resistance?
Translated on 31-10-2026, 5:56.
harj Guest
12-02-2007, 19:15 Subject: Clutch Not Disengaging: Causes & Fixes |
Thank you for your answers!
According to the mechanic, the printing plate is broken.
Best regards.
Sepp.
Translated on 31-10-2026, 5:57.
Ibi6L-ASZ Blaumann
Joined: 07/20/2005 Posts: 56 Karma: +3 / -0 Location: Bochum 2004 Seat Ibiza Free account, no CAN development support
23-03-2007, 12:13 Subject: Clutch Not Disengaging: Causes & Fixes |
Hello everyone, recently, the clutch on my ASZ engine isn't disengaging properly.
However, this is not a permanent problem, but rather occurs sporadically when the engine is cold and during city driving.
When I'm at a red light and press the clutch pedal while keeping the gear engaged, I can feel the clutch slipping and the engine trying to pull the car forward. When I release the brake, it starts to roll forward.
What should I be looking for? The problem is not reproducible, and I first noticed it about a week ago.
Sebastian. BMW 123d Coupe
Translated on 31-10-2026, 5:58.
Profile PM Garage |
23-03-2007, 13:21 Subject: Clutch Not Disengaging: Causes & Fixes |
Does the clutch engage quite low down? Aktuell:
Ibi6L-ASZ Blaumann
23-03-2007, 13:44 Subject: Clutch Not Disengaging: Causes & Fixes |
If it doesn't separate properly, the cutting point shifts all the way down, and it closes much earlier.
If the problem isn't currently occurring, the point where the friction occurs is located relatively high up in the pedal stroke. BMW 123d Coupe
Translated on 31-10-2026, 5:59.
Profile PM Garage |
