A4 8D Document: Timer Stuck - Troubleshooting (Solution)
Michael II
Post09-01-2003, 12:48    Subject: A4 8D Document: Timer Stuck - Troubleshooting Quote
The daily mileage counter resets, and the clock stops when the ignition is turned off/on.
Affected vehicle identification numbers:
AUZZZ8DZTA000000 - 999999
Cause:
The connection to terminal 30 in the control panel housing is incorrectly wired. Even after optimization starting with chassis number 8D VA 205 000, individual defects still occur.
Solution:
Check the wiring to terminal 30 on the distribution board module according to the wiring diagram and fuse S15 (10A).
Tschüss
Michael II
Translated on 30-08-2026, 18:03.
Ratings - A4 8D Document: Timer Stuck - Troubleshooting
No new posts Audi 8E2 Wiper Problems: Fix Sticking Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lupo Tachometer Problem: 6X1 MJ 2002 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2001, Clutch pedal remains at the bottom Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVB: Intermittent Freezing Issues Diesel Engine Technology
No new posts T4 111kW jerks/stalls Diesel Engine Technology
No new posts ACV Stuck: "Scheppern" Explained - The Logic Behind It Upload
No new posts ESP Wave Alignment: Cylinder 1 Diesel Engine Technology
