A4 Doku: Emergency Mode After Heavy Load (KW 09/1999) (Solution)
Michael II
Post09-01-2003, 12:54    Subject: A4 Doku: Emergency Mode After Heavy Load (KW 09/1999) Quote
After strong acceleration, the engine enters limp mode, with error codes 18047 or 00777 indicating an "implausible signal from the throttle position sensor."
Cause:
In the throttle position sensor, increased wear on the potentiometer track can lead to an insulating layer with occasional voltage drops. In case of a fault, the gasoline engine will reduce torque by 50%, and the diesel engine will go into limp mode at 1500 rpm. After turning the ignition off and on again, the intermittent error is reset, and the vehicle regains full engine power.
Solution:
Spare part.
Only the pedal module manufactured by Hella is affected.
Tschüss
Michael II
Translated on 16-08-2026, 7:33.
Ratings - A4 Doku: Emergency Mode After Heavy Load (KW 09/1999)
No new posts Document: A4, Emergency Procedure After Strong Acceleration Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Oil warning light after cold start, all models ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A4 8D, production period up to 09/1999, cigarett... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AXR Performance Issues After ZKD Replacement Diesel Engine Technology
No new posts TDI Cold Start: Emergency Mode Troubleshooting On-Board Diagnostics (OBD)
No new posts Cold Start Problems? Emergency Mode Explained. Diesel Engine Technology
No new posts Emergency mode after disconnecting EGR valve on a 2.0 DTI... Diesel Engine Technology
