HI,
In the vehicle's onboard network control unit (ECU), you can mark virtually anything as "installed."
Why isn't it done in a way that reflects reality?
I have a Climatronic system, but that bit is not set.
After installing the ";)footwell lighting}", I also installed it in the MFA Plus... now all that's left to do is install and wire the lamps }.
Okay, please provide the German text you would like me to translate into English. I will only provide the translation. Transparency, Teamwork
Translated on 13-07-2026, 21:59.
