ECU Programming: How to Learn/Calibrate
rob
Post08-04-2007, 17:59    Subject: ECU Programming: How to Learn/Calibrate Quote
hello
To my "never-ending story."
Error code 17981 in the mass flow controller's fault memory.
The car starts, but then immediately accelerates to full speed.
"Remanufactured pump installed... car won't start anymore !?!?"
"Get the control unit checked... unfortunately, it's defective (short circuit)."
after the repair, the error is still there icon_cry.gif.
"Another test of the control unit revealed that 'the software seems to be a bit messed up (you wouldn't believe what can happen...)'."
"I had a new EEPROM and software installed, but it still doesn't work..."
However, there are no more errors in the memory.
I also switched the pump back to the old one (which wasn't actually defective).
What now???
Does the control unit need to be reprogrammed?
It should at least start up once.
Thank you for any advice.
Translated on 05-10-2026, 6:06.
bastion
Karma: +6 / -1   Thank you, like it!
Post08-04-2007, 18:45    Subject: ECU Programming: How to Learn/Calibrate Quote
It's likely that the pump is misadjusted. Even a few millimeters can cause the motor to over-rev.
A4 Avant 08/01 AWX 05/08-
Translated on 05-10-2026, 6:07.
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Model 2014 Key Programming via VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts control unit settings On-Board Diagnostics (OBD)
No new posts AAT/AEL Control Unit: Function & Troubleshooting On-Board Diagnostics (OBD)
No new posts 1Z Control Unit: No WFS? On-Board Diagnostics (OBD)
No new posts B4 TDI ECU: Troubleshooting & Repair On-Board Diagnostics (OBD)
