Ich weiß nicht mehr weiter, Hilfe mein TDI spinnt !!! | Posts 32+
Go to page: Previous  1, 2, 3
Post26-12-2002, 22:45    Subject: Quote
Hello Andre,
If the engine control unit does not receive the speed signal, the anti-kickback function of the control unit will not work, and the car will tend to jump or "kangaroo."
The speed sensor is located on the transmission differential, so check the cables and the sensor there.
Translated on 01-09-2026, 18:06.
reuselkopp
Post13-01-2003, 22:35    Subject: Quote
Hello everyone,
I have another question. After I deactivated the AGR (Abgasrückführung), my car ran quite well for about 1000 km. Now, it's starting again where the car doesn't run with full power.
As Ulf told me, I once checked the intake manifold for contamination and found a layer of oil about 5mm thick inside. But that's not all! If the two-way valve that regulates the vacuum to the EGR system fails, does the EDC (Electronic Diesel Control) then go into limp mode?
"Something isn't right; I'm also having problems when braking. It's not that the pedal gets soft with repeated pumping; it's the opposite. The pedal gets harder and harder. Then, after about a minute of not braking, the pedal becomes soft again. Could the vacuum pump be defective? However, if you disconnect the hose that runs from the pump to the two-way valve, you can feel that the pump is indeed creating a vacuum. Maybe it's not creating enough?"
Okay!
I am waiting for your answers.
Best regards, Reuselkopp.
Translated on 01-09-2026, 18:08.
Uwe
Post13-01-2003, 22:57    Subject: Quote
@reuselkoppViewing profile: reuselkopp
reuselkopp wrote:
. . . I also have problems when braking. It's not that the pedal becomes soft after repeatedly pressing the brake pedal, but quite the opposite. The pedal becomes harder. Then, if I haven't braked for about 1 minute, the pedal becomes soft again.
That sounds like there's air in the brake hydraulic system -> you need to bleed the brakes!
Uwe
Translated on 01-09-2026, 18:10.
reuselkopp
Post13-01-2003, 23:13    Subject: Quote
But if there was air in the brake hydraulic system, wouldn't the pedal feel softer and not harder?
What causes the EDC (Electronic Damping Control) to go into emergency mode if my two-way valve is broken?
Reuselkopp.
Post14-01-2003, 10:45    Subject: Quote
reuselkopp wrote:
What does a faulty two-way valve cause that makes the EDC go into emergency mode?
Which valve are you referring to?
If an emergency mode is activated, an error code is stored -> read it out.
Translated on 01-09-2026, 18:11.
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Radio Problem: Fix for 8L Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Corroded VTG rod, don't know what to do next. Diesel Engine Technology
No new posts Help, my car won't start! Diesel Engine Technology
No new posts Car Repair Problem? Get Expert Help Now! Diesel Engine Technology
This topic is locked, you cannot edit or reply. 1Z Issues: Troubleshooting and Solutions Diesel Engine Technology
