Tire Pressure Monitor: Retrofit & Coding
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Post02-05-2007, 9:49    Subject: Tire Pressure Monitor: Retrofit & Coding Quote
HI.
The ABS sensors in the 3C can be used to monitor the tires.
This is NOT the tire pressure monitoring system; instead, it's the switch located on the upper right side of the gear lever, the "other" switch.
The extra part costs 53 EUR, so it's probably just the switch, like with the Auto-Hold system.
I forgot about it and now want to add it. But I can't find anything to use for encoding.
Or is simply installing the switch enough?
Translated on 02-09-2026, 18:04.
No new posts Retrofitting heated seats? Transmission, Chassis, Body & Interior
No new posts Retrofitting a freehub to a Lima hub Diesel Engine Technology
No new posts A6 4G Cornering Light Coding On-Board Diagnostics (OBD)
No new posts Motorsteuergerät Golf IV kodieren On-Board Diagnostics (OBD)
