Fuel Return Valve Location: AVF TDI PD (2002)
Mike3BG
Post04-05-2007, 8:35    Subject: Fuel Return Valve Location: AVF TDI PD (2002) Quote
Hello!
Can someone please provide me with information about whether the AVF TDI PD (Passat 3BG, year 2002) also has a fuel return valve (ball valve)? The first AVF, up to chassis number: xyz, with a different fuel filter and an additional fuel-water cooler, has one located next to the fuel filter. The updated AVF, from 2002 onwards, has a modified fuel filter without an external fuel cooler, but unfortunately, it no longer has this return valve, at least not in that location. My question is: where is this return valve? I can't believe that the updated AVF no longer has this return valve icon_rolleyes.gif. Isn't it supposed to prevent fuel from flowing back into the tank when the engine is not running?
Thank you.
Greetings.
Translated on 21-09-2026, 11:10.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post04-05-2007, 17:08    Subject: Fuel Return Valve Location: AVF TDI PD (2002) Quote
Hello, it looks like it's located directly in the supply line to the engine. Please take a close look at the hose to see if it's thicker anywhere.
In the AKTE system, I can't find a check valve as a spare part. icon_biggrin.gif Or rather, there's only a valve for the old filter with the thick radiator on top. } The new one probably has it welded into the hose or something. }
B.Eng (FH) u. KFZ Meister
Translated on 21-09-2026, 11:11.
Mike3BG
Post07-05-2007, 7:10    Subject: Fuel Return Valve Location: AVF TDI PD (2002) Quote
Hi, that's exactly my problem icon_exclaim.gif. Where the old one was, there isn't anything now, and nothing is visible in the catalog icon_rolleyes.gif.
I once heard from someone that it is supposed to be located in the tank, near the pre-pump icon_exclaim.gif icon_question.gif. Whether THAT is true icon_rolleyes.gif.
Greetings.
Translated on 21-09-2026, 11:12.
No new posts Audi A2 Noises: 8Z0 MJ 2002 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wind Noise in Audi A2 (8Z0) 2002: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf 4 Inspection Interval: 2002 Model Diesel Engine Technology
No new posts CAN Distributor A4 2002 - For Sale On-Board Diagnostics (OBD)
No new posts Passat TDI 2002: Euro 3 Specs & Info Diesel Engine Technology
This topic is locked, you cannot edit or reply. Volkswagen Golf IV, 90 HP TDI, 2002, gas stuck/not working Diesel Engine Technology
