Error 16955/17978: Causes and Solutions
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post10-05-2007, 20:35    Subject: Error 16955/17978: Causes and Solutions Quote
Hello, after trying to search and unfortunately not quite understanding the context, here's the process:
The preheating spiral on the Sharan AHU is illuminated, and I'm reading a single error code: 16955, which indicates a problem with the brake light switch.
After the error was cleared, the problem reappeared: the brake lights are not working.
"Bought a switch, now I'm getting two error codes: 16955 and 17978. The motor is locked!"
Heart slipped into pocket 'icon_rolleyes.gif'
After installation: all errors cleared!
Started with the brake pedal pressed - stalled. Restarted without the brake pedal - it runs.
Engine control unit fault... it's back again.
Errors fixed and clean.
I haven't done anything else related to the immobilizer or the key.
I know that the switch also cuts off power during braking, and that it has two opposing switches. But I'm wondering why the main control unit is being blocked.
If it's supposed to be normal, why weren't both errors present at the same time?
Please explain to me why.
Thank you in advance.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 06-09-2026, 20:36.
BM
Avatar-BM
Post10-05-2007, 21:46    Subject: Error 16955/17978: Causes and Solutions Quote
Started with the brake pedal depressed - stalled.
When he left, he probably experienced occasional instances where the key was not recognized.
For example, in older Polo 6N models, the problem is often due to the connectors, which cause the signal to be too weak.
What does the fault memory of the WFS (Vehicle Information and Entertainment System) or the instrument cluster say?
3B5 AJM
Translated on 06-09-2026, 20:38.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post10-05-2007, 22:02    Subject: Error 16955/17978: Causes and Solutions Quote
Hi, it's a Sharan, not a Polo, but whatever.
I checked for all errors, not specifically WFS errors, but all errors were found.
However, it's not yet being done with VAG-COM, as that functionality isn't working yet; instead, it's being done with Techmess.
Okay, so I understand correctly - there's no connection to the BL switch story?
Translated on 06-09-2026, 20:39.
BM
Avatar-BM
Post10-05-2007, 22:11    Subject: Error 16955/17978: Causes and Solutions Quote
Hello, Sharan not Polo but it doesn't matter,
It was just meant as an example.
So, am I understanding correctly - there is no connection to the BL switch story?
Normally, no.
3B5 AJM
Translated on 06-09-2026, 20:40.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post10-05-2007, 22:22    Subject: Error 16955/17978: Causes and Solutions Quote
Ah-yes, thank you.
Okay, I'll check back on the FSP again sometime to see if the WFS error reappears.
I also have to delve into the VAG-COM software to find the WFS.
At Techmess, the address is simply the engine control unit or WFS/ABS, etc.
Thank you again.
Translated on 06-09-2026, 20:41.
No new posts Caddy Bj 07 BLS AGR Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Needle Lift Sensor & Air Temp Sensor Issues? On-Board Diagnostics (OBD)
No new posts Error Codes 00575 & 17978: Troubleshooting Help On-Board Diagnostics (OBD)
No new posts Passat Electrical Issues: VAG COM Fault Codes 18080 &... On-Board Diagnostics (OBD)
No new posts Relationship between LMM and boost pressure? Diesel Engine Technology
