Bremse VL löst nicht richtig | Posts 16+
Go to page: Previous  1, 2
Rudi
Post23-04-2007, 21:55    Subject: Quote
Make sure the central screw of the drive shaft is 'properly' tightened icon_question.gif.
icon_eek.gif ... I will check it tomorrow morning, before I take it away.
Herr Antje
Post24-04-2007, 6:35    Subject: Quote
It might be temperature-dependent because your glass panel becomes locally hotter over time, which causes it to warp.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Rudi
Post25-04-2007, 14:55    Subject: Quote
And what did the micrometer say? Not that you'll need to replace the windshields again soon...
The rim had a dent, but the hub did not. Today, the news arrived that a bearing housing...
It has some damage (I don't have any more details about it yet). Since the parts dealer is also a...
If the wrong wheel bearing was delivered, the solution to the puzzle will not be revealed until tomorrow icon_evil.gif.
@BM: The central screw was tightened correctly.
Regarding the tightening torque, I'm once again confused about the difference between the positive axis and the base axis.
noticed.
Does anyone know a reliable distinguishing feature?
According to the Bilstein shock absorber test report, the catch basin on the plus axis is not covered.
features star-shaped reinforcing ribs, while the base axis has a fang-shaped protrusion.
It is covered with a plastic cap and has no reinforcing ribs.
After that, my Golf will have a plus-size option.
Other sources claim, however, that the plus axle is only used in conjunction with five-hole rims.
Rudi
Herr Antje
Post25-04-2007, 15:22    Subject: Quote
As far as I know, the Plus axle always has 5-bolt hubs and 280mm (later 288mm) discs at the front.
Now available in our online store:
According to an online parts shop, the brake pads come in two versions: one with a "+" marking and one without. The shop states that the difference is visible in the color of the brake caliper (red) and the number of mounting holes (5). Apparently, this 5-hole design is found in the 110 PS TDI (AFN?) engine.
However, there are also 280 tires with a 4-hole pattern, such as those used on the G60. However, it doesn't have a positive axis.
Aktuell:
Rudi
Post09-05-2007, 10:52    Subject: Feedback Quote
Okay...
The car is running again icon_cool.gif.
Ultimately, it was the wheel bearing that failed; a crack had formed in one of the bearing races (possibly due to a material defect).
and a damaged wheel bearing housing.
It's difficult to say what died first and dragged the rest down with it.
It probably didn't help that I drove another 700 km with the problem.
improved icon_confused.gif.
To avoid any further risk, we also replaced the hub.
It appears that the axis in question is the base axis.
Rudi
Post11-05-2007, 8:35    Subject: Re: Feedback Quote
Rudi wrote:
Ultimately, it was the wheel bearing, where (a material defect?) caused a bearing shell to crack, and a worn-out wheel bearing housing.
What died first and dragged the rest down with it is hard to say, and the fact that I drove another leisurely 700km with the problem certainly didn't improve things icon_confused.gif.
Were there any "new sounds" involved?
(I suspect it's probably just the usual grinding/whining noise, but perhaps there was something atypical that other people might keep in mind as a potential clue.)
No new posts Audi A3 8P: Floor Covering Detaching Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Sharan, Folding table with backrest detaches Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Door Seal Repair: 2000 Model Drip Cover Issue Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rear brakes not engaging properly on VW Golf G4 Transmission, Chassis, Body & Interior
No new posts Parking brake not releasing!! Transmission, Chassis, Body & Interior
No new posts ARL Issues: Troubleshooting & Solutions On-Board Diagnostics (OBD)
No new posts Not working properly Diesel Engine Technology
