[Benziner] Polo 9N AZQ lässt das Gas beim Schalten stehen | Posts 16+
Go to page: Previous  1, 2
Post17-05-2007, 19:25    Subject: Quote
Hello Ulf,
I've only tried it without using much force so far, but that didn't work.
The black, round part is minimally rotatable within the blue casing, and that's all it does. Sure, I will.
Currently, I'm troubleshooting an issue with the brake pedal switch on a Golf. It's a sporadic fault on sensor G201, with the additional code 008, which, according to the error database, indicates a problem with the brake light switch. However, it is currently not being produced anymore, so the switch (~8 €) is only available in limited stock.
There's a lot of switch failure happening right now icon_rolleyes.gif ...
//edit: Or are you only referring to the removal of the pedal bracket? That's easily done. According to the repair manual, however, the switch should not be used after that, because it will no longer provide a secure connection. The newcomer was already very well-fed.
 File size:  47.25 KB
 Viewed:  4790 times
 File size:  44.21 KB
 Viewed:  4710 times
 File size:  45.13 KB
 Viewed:  5705 times
Post18-05-2007, 6:46    Subject: Quote
Roger wrote:
Or are you only referring to the disassembly of the pedal bracket? That should be no problem. According to the instructions, however, the switch should not be used again afterwards, because it will no longer provide a secure hold. The new one also clicked in very securely.
Yes, that's exactly what I meant: it seems that some kind of locking mechanisms or similar components wear out or become damaged after just one or two assembly and disassembly cycles?
Post18-05-2007, 10:03    Subject: Quote
That's quite possible, I haven't tried mounting a second derailleur on the pedal bracket. However, removing the old part was easier than installing the new one...
Do you have a crafting activity planned for icon_wink.gif?
Post18-05-2007, 11:10    Subject: Quote
ulf wrote:
Then it seems that some kind of
"fixation devices" or similar things are used up after just one or two times of being mounted and dismounted?
No, much simpler.
Safety-critical components must only be installed once.
The brake light switch is defined as such.
There's also a "great" part in the Phaeton.
The hazard light switch.
It belongs to the multimedia unit and should not be installed again.
These components are called DMBA parts. All assembly work performed on them must be fully documented and (permanently) archived. Therefore, the name:
Documents with Special Archiving.
Post18-05-2007, 11:33    Subject: Quote
No, I'm just asking as a precaution.
Safety-relevant components must only be installed once.
Okay... could you summarize in a few (general) words which other parts of the entire vehicle are included?
And since when / from which model year does this apply?
Post18-05-2007, 11:53    Subject: Quote
All parts that the repair manual specifies. These components are already defined as such during the approval process with the KBA (German Federal Motor Transport Authority).
The brake light switch is always included. There are similar regulations for almost all parts related to safety (seatbelts, airbags, etc.). If a DMBA part is explicitly designed for disassembly and reassembly, this will be mentioned. In the past, brake light switches weren't made of easily damaged plastic and were more robust, so they could be reused after being cleaned.
1937... Since the introduction of vehicle type approval.
However, it is only in recent times that this has been paid very close attention to. Particularly with components that can suffer "imperceptible" damage during disassembly, such as plastic brake light switches.
Post18-05-2007, 13:06    Subject: Quote
Aha, thank you for the clarification, on my part as well icon_smile.gif.
But does that also apply to clutch monitoring - surely it wasn't installed in 1937 icon_lol.gif?
No new posts A4 8D Document: Timer Stuck - Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 8E2 Wiper Problems: Fix Sticking Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clicking sound when shifting, Golf Diesel Engine Technology
No new posts Audi A6: Gear Shifting Jerk - Troubleshooting Diesel Engine Technology
No new posts VW Polo 6N2 Won't Start - WFS Error Codes On-Board Diagnostics (OBD)
No new posts Polo diesel with a gasoline transmission??? Diesel Engine Technology
