martsch
17-04-2007, 7:50 Subject: DIY Diagnostic Adapter: Troubleshooting Help! |
Approximately 1 1/2 months ago, I purchased a DIY diagnostic adapter COM kit. Following advice from forums and other sources, I didn't buy a diagnostic adapter from ebxx. Unfortunately, I've had a lot of trouble with the kit. It simply doesn't work; I can't read any data, although VAG-COM recognizes it. I've tried to eliminate the potential error sources that Rainer suggested, as much as I could. However, I'm not an electrician.
Since I can't find a solution myself, and even an acquaintance who works with electrical systems couldn't help me further, I'm wondering if anyone would be willing to take a look at the device or repair it?
I would send it to the person with the hope of getting it back  , along with the money for return shipping plus €10. I hope that it will work out then.
I would be happy if someone were to get in touch.
Martin.
Translated on 13-08-2026, 10:53.
Bastelfred Blaumann
Joined: 01/09/2004 Posts: 51 Karma: +6 / -4 Location: bei Schwerin
17-04-2007, 21:32 Subject: DIY Diagnostic Adapter: Troubleshooting Help! |
"Please take a picture of the part, both sides. Make sure it's not just an assembly error. I have one too, and mine worked perfectly right away."
If the ICs were socketed, I would definitely take a look at yours, but with these soldered-in ICs, I can't easily remove them without damaging anything.
Have you desoldered any components again? Unfortunately, it's very easy to damage the circuit board in the process.
Translated on 13-08-2026, 10:55.
Otter
20-04-2007, 16:36 Subject: DIY Diagnostic Adapter: Troubleshooting Help! |
Where did you buy the kit?
I think the manufacturer or supplier should offer you support and a warranty in this case.
Please provide the text you would like me to translate from German to English. I will then give you only the translation, without any explanations.
Translated on 13-08-2026, 10:56.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
20-04-2007, 16:54 Subject: DIY Diagnostic Adapter: Troubleshooting Help! |
Sure, here's the translation of the German text into English:
"There:"
http://shop.dieselschrauber.de/
Translated on 13-08-2026, 10:57.
Profile PM WWW Garage |
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
21-04-2007, 21:17 Subject: DIY Diagnostic Adapter: Troubleshooting Help! |
Otter wrote: | Hello,
Hello, and how can any manufacturer or supplier possibly guarantee that a kit will be assembled/soldered correctly?
He must have already provided some assistance, as I can see.
Best regards, Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Profile PM Email Garage |
22-04-2007, 17:27 Subject: DIY Diagnostic Adapter: Troubleshooting Help! |
Quote: | | He must have already provided some assistance - as I read... |
Sure.
But I'm not going to sit around and try to figure out what someone has haphazardly thrown together; that's why you can buy the device ready-made and with a warranty.
If you follow the instructions, it will work. I've also included a list of the most common mistakes directly within the instructions on the CD.
Translated on 13-08-2026, 10:59.
22-04-2007, 18:17 Subject: DIY Diagnostic Adapter: Troubleshooting Help! |
Okay, I understand. Please provide the German text you would like me to translate into English. I will only provide the translation. Gruß, der Teileklaus
Translated on 13-08-2026, 11:00.
martsch
19-05-2007, 9:16 Subject: DIY Diagnostic Adapter: Troubleshooting Help! |
Since I've only been back home for a few weeks and the diagnostic connector was there, I unfortunately can only write now. The pictures aren't very good; the camera simply can't seem to focus properly, even manually, but I hope it will be enough.
[img]/download.php?id=2138[/img]
Thank you all for your answers.
Ralle Ratlos Blaumann
Joined: 04/14/2007 Posts: 4 Karma: +2 / -0 Location: PM - hoher Fläming
19-05-2007, 20:33 Subject: DIY Diagnostic Adapter: Troubleshooting Help! |
Where do you live, "martsch"? Sonntags: Dehler 2,5 AHY
Wochentags: T4 AAB Salatölantrieb
Translated on 13-08-2026, 11:01.
19-05-2007, 21:04 Subject: DIY Diagnostic Adapter: Troubleshooting Help! |
At least the RS232 cable is connected incorrectly... In my opinion, the manual on the CD states:
- green
- red
- purple
- orange
19-05-2007, 21:06 Subject: DIY Diagnostic Adapter: Troubleshooting Help! |
It's hard to tell from the picture, but I think one of the 1uF electrolytic capacitors is also incorrect.
(This is also a common error and is mentioned in the manual on the CD.)
Translated on 13-08-2026, 11:02.
martsch
02-06-2007, 23:30 Subject: DIY Diagnostic Adapter: Troubleshooting Help! |
hello,
I just wanted to thank Rainer again; the adapter for the building kit is finally working  . It's truly amazing; it was actually due to the swapped cables that I didn't notice. I measured everything, etc., but I never thought of something so simple. Anyway, thanks again; now I can start the diagnosis  .
Translated on 13-08-2026, 11:03.
martsch
03-06-2007, 17:59 Subject: DIY Diagnostic Adapter: Troubleshooting Help! |
Now that I've finally managed to get my adapter working, and I don't want to start a new thread, I'm posting this here. The problem with my maximum speed persists; it only reaches 200 km/h with great difficulty. Therefore, I have logged the MWB values 3-8-11. Perhaps someone can help me identify the cause. Furthermore, I have another question: what could be the reason that after 30 attempts, I can only get one decent log? Before that, it always crashes, for example with an error message like "ECU not responding," etc. It seems completely random when I manage to get a good log without it almost crashing.
Here is my log for the MWB 3-8-11.
Log file: /download.php?id=2185
Translated on 13-08-2026, 11:04.
