Search logs with MWB 8+10, various MKBs.
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Post08-06-2007, 12:01    Subject: Search logs with MWB 8+10, various MKBs. Quote
For a possible technical tip for detecting intake air leaks, a faulty/stuck/open AGR valve, restricted air filter, or a clogged catalytic converter, based on log data, I need logs with RPM and MAF (Mass Air Flow) readings, preferably with both MAF 8 and MAF 10 readings simultaneously.
In the logs, there should be as much full-throttle acceleration as possible, ideally between approximately 1500 and over 4000 rpm, with the higher the gear, the better. Partial load operation at various speeds is also welcome.
Logs that were generated during the aforementioned {PROCESS} Defective runs would be particularly interesting, as I want to investigate how they relate to the ratio of air mass / charging pressure (both in the MWB 10!).
Please simply upload the logs in the online upload area: /viewforum.php?f=40
A presentation with graphics or anything else is not necessary. But please make sure not to post any CVs with large groups of numbers online, or format data as text: preparing such things properly is really a pain . . .
If someone has uploaded logs, or if they have already been disabled, please post the corresponding link here as a (minimum) response.
Thank you!
No new posts Doku Fahrverhaltensmängel diverse MKB Fehler und Dokumentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 8E2/8E5 - diverse Fehlerspeichermeldungen möglich Fehler und Dokumentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Werkstattaktion Nockenwellenverschraubung, diverse PD Fehler und Dokumentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Abgasrückführventil, diverse 2.0l TDIs Diesel Motorentechnik
No new posts Passat 3BG AVF geht aus, diverse Relaisfehler Diesel Motorentechnik
No new posts Galaxy fährt im Notlauf (diverse Fehlereinträge) On-Board-Diagnose (OBD)
No new posts AXR-Logs von TS Upload
