IBIZA 6L Comfort Control Unit
legolas09
Post30-08-2006, 10:21    Subject: IBIZA 6L Comfort Control Unit Quote
The following coding applies to the engine control units (ECUs) with part number 6Q0 959 433E used in the Ibiza.
Select STG 46 (comfort system).
ECU coding -> Function 07.
Central locking (2-door/without power windows):
00016 - Single door opening.
00017 - Complete door opening.
Central locking (4-door/without power windows):
00018 - Single door opening.
00019 - Complete door opening.
Central locking (2-door/2-window lifters):
00064 - Single door opening.
00065 - Complete door opening.
Central locking (4-door/2-window lifters):
00066 - Single door opening.
00067 - Complete door opening.
Central locking (4-door/4-window lifters):
00258 - Single door opening.
00259 - Complete door opening.
Now I've noticed that on some two-door models with the 2FH option, the display sometimes shows '16' instead of '64'... if that's the case, I can't activate the window opening and closing function using the remote control.
Changing the value from 16 to 64 in VAG-COM now results in an error message indicating that no door control units are detected.
Does anyone know what that's all about?
Translated on 29-10-2026, 14:57.
Ross-Tech-Support
Post30-08-2006, 10:35    Subject: IBIZA 6L Comfort Control Unit Quote
Are you sure that the eFH are standard equipment?
Translated on 29-10-2026, 14:59.
legolas09
Post30-08-2006, 11:12    Subject: IBIZA 6L Comfort Control Unit Quote
Yes, that's what's happening... It's not just happening with one IBI (Integrated Body Module), but with several now... The other functions are working fine... When I select code 64, it displays the message that it can't find the door control modules, as I mentioned.
--> IBI MJ04,05
P.S. You should be receiving a package today icon_wink.gif.
Translated on 29-10-2026, 15:00.
Pushy
Post14-06-2007, 20:47    Subject: IBIZA 6L Comfort Control Unit Quote
Okay, I'm experiencing the problem you described. I drive a Seat Ibiza Cupra TDI, manufactured in September 2005, model year 2006 (production started in May 2005).
Here are the findings so far:
The power windows can be operated up and down via the door lock on the driver's side.
There is no response when using the remote control.
I have electrically adjustable and retractable, as well as heated, exterior mirrors.
In addition, I also ordered the anti-theft system with interior protection. The interior protection can now be deactivated separately via the remote control, while until around 2004, a switch was installed inside the vehicle.
I have made several attempts with a friend to reprogram the control unit in order to also be able to use the comfort functions via the remote control.
My car also has electric front windows as standard (3-door model). In the comfort control module (code 46), "16" is also coded (despite the electric front windows). Programming it to "46" doesn't result in any visible changes. In VAGCom, nothing is displayed when the coding is "16", and no front left or front right door control modules are found when the coding is "64".
Regarding the door control modules, I'm a bit unsure at the moment. My acquaintance (who has a VW Bora TDI, year 1999) needed new window lift motors along with the door control modules when he retrofitted the electrically folding exterior mirrors.
I hope someone can still provide a logical explanation of what else can be tried, or why it's no longer possible.
Translated on 29-10-2026, 15:02.
No new posts Speed Control Retrofit Seat Ibiza / Polo Troubleshooting & Guides
No new posts SEAT IBIZA GT TDI 110hp Diesel Engine Technology
No new posts IBIZA 6K with engine code 1Z, no power On-Board Diagnostics (OBD)
No new posts Retrofitting DAB+ radio for Seat Ibiza 6J FR SC 2.0 TDI, ... Electrical Systems, Vehicle Electronics, Multimedia
No new posts [IBIZA 6K] The sunroof suddenly operates automatically... Transmission, Chassis, Body & Interior
