Diesel Additives: Improve Fuel Efficiency & Performance
anton
Post18-01-2003, 14:09    Subject: Diesel Additives: Improve Fuel Efficiency & Performance Quote
What do you think about diesel additives? I've heard that you have to, for example, add engine oil to kerosene and, and in the winter, use the product MINUS or gasoline if you don't use winter diesel. However, I've read that gasoline can damage the ESP (Electronic Stability Program) due to the removal of the lubricating film, especially if you have a common-rail engine. Can you prophylactically add engine oil to prevent wear, or does that achieve the opposite, especially if it increases the viscosity of the fuel, particularly during the winter? What about other additives, such as those from LiquiMoly?
Thank you for your tips and your opinions.
Your newbie, Anton.
PS: What kind of technology does my 1988 Ford Orion/Escort 1.6l diesel engine have? Definitely not CR, more likely PD, but which one? Is it a single-row injection pump or a distributor injection pump? Is it true that VESPs are practically indestructible? Please say yes icon_wink.gif.
Translated on 26-08-2026, 4:26.
diesel.gustav
Post18-01-2003, 23:30    Subject: Diesel Technology: Do You Really Know It? Quote
Deleted upon request.
Translated on 26-08-2026, 4:28.
anton
Post19-01-2003, 1:00    Subject: Diesel Car: My First! Quote
The pump is a Bosch pump, but I have to admit, I don't know the difference between a common rail pump and a distributor pump. However, thanks to you, I now know that it's a distributor pump. I enjoy experimenting with fuels and I'm considering mixing vegetable oil with diesel to save money and protect the environment. That's why I wanted to know how robust my ESP is, because this component seems to be both 1. the most expensive and 2. the most likely to break.
Anton.
Translated on 26-08-2026, 4:29.
Gremlin
Post19-01-2003, 12:14    Subject: Diesel Additives: Improve Fuel Efficiency & Performance Quote
Take a look inside here: https://community.dieselschrauber.org/en/viewtopic.php?t=1405
Okay, I'll quickly copy your post here.
(RB = Robert Bosch GmbH)
Fuels approved by RB for use:
Diesel fuel according to EN 590 (2000).
Sulfur-free diesel fuel (sulfur content < 10 ppm).
According to EN 590.
Diesel fuel according to EN 590, with up to 5 Vol.% FAME 1).
according to draft prEN 14214.
Diesel fuel with additives, produced by mineral oil companies.
to be approved, provided that EN 590 is complied with.
Diesel fuel according to JIS K 2204: 1 and 3, if lubricity is...
According to EN 590 (provided successful testing).
Diesel fuel according to ASTM D 975: 1D and 2D 3), if lubricating...
Ability according to EN 590 (provided successful testing).
1) Fatty acid methyl esters (biodiesel)
2) Japanese standard
3) US standard
Fuels that do not have a general approval from RB.
to receive the allocation; individual approval may be required, possibly with specific conditions.
Package available after successful testing:
Poor lubricating diesel fuel with an HFRR value greater than 460 µm.
<650> 5 Vol.%.
Diesel fuel with additives for exhaust gas aftertreatment (e.g., additives).
(based on cerium and iron)
Customer testing will be conducted in coordination with RB.
All costs incurred by RB will be passed on to the customer.
Bill issued.
* including additives for diesel fuel.
Fuels that are not currently being tested at RB.
and did not receive approval for deployment:
Gasoline.
Petroleum and other types of kerosene.
Alcohols (methanol, ethanol, isopropyl alcohol as antifreeze, etc.)
Diesel fuel with additives that are available in accessory stores (e.g., ...).
Lubricity improvers, flow improvers, cetane improvers, etc.
Diesel fuel containing dissolved water.
Diesel fuel-water emulsions (Aquazole).
Diesel fuel mixtures with used oil.
Diesel fuel with the addition of biocides.
Marine distillate fuels (e.g., ISO 8217) *
Heating oil (e.g., BS 2869)
'Cu Gremlin'
Translated on 26-08-2026, 4:33.
No new posts Customer reviews of diesel additives and valve cleaners Diesel Engine Technology
