Kaltstartproplem beim 1Z nicht gelöst *heul* | Posts 192+
Go to page: Previous  1, 2, 3 ... 11, 12, 13
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
Gremlin
Post17-01-2003, 21:24    Subject: Quote
I've now run my RAID array again icon_wink.gif.
Okay, here's what happens during startup: The fuel quantity control unit is set to the initial fuel quantity. As the engine speed increases, the feed pump builds up pressure in the pump housing (and it needs at least 150 RPM for this, meaning the starter motor needs 300 RPM!). Only when this pressure is high enough can the injection timing advance. The injection start timing is NOT controlled at this stage; it's not possible yet because reliable signals from the needle lift sensor are not available. Instead, it's controlled based on a lookup table (map). Initially, the valve for injection start is closed, and the injection start advances to its maximum early position as the pressure increases. Once the engine starts and usable signals from the needle lift sensor are available, the injection start timing is regulated.
If the device ('the box') doesn't start up when it's around 0 degrees, here are some scenarios that I can think of:
- The valve for the start of injection is stuck.
- The pressure valves for the injection line are worn out.
- The booster pump is worn out.
- The pressure regulating valve is worn out.
- starter speed too low.
- Defective temperature sensor (water or fuel).
Please remember, there are the most incredible coincidences (you know them all).
It wouldn't be the first component to fail only within a specific temperature range.
'Cu Gremlin'
Translated on 11-07-2026, 5:02.
diesel.gustav
Post17-01-2003, 23:12    Subject: Such a case is probably a moderate fiasco? Quote
Deleted upon request.
Translated on 11-07-2026, 5:04.
christians
Post18-01-2003, 0:22    Subject: Quote
He's right where he's right. I can barely get my own (rather sporadic) posts out of my head, let alone keep track of them in sequence.
I think it would be best if Christian started a new thread with a summary of the old one.
So, the problem is: what exactly was done, what was proposed before, and why didn't it work?
Perhaps a more detailed analysis will reveal several different themes. Unfortunately, I lack the overview and am too lazy to read everything again.
Gruß Christian
Translated on 11-07-2026, 5:05.
Post18-01-2003, 11:11    Subject: Subject: Is this kind of case likely to be a moderate failure? Quote
diesel.gustav wrote:
...Ich bin kein Stammgast hier und kann auch auf Wunsch jederzeit wieder verschwinden...
Hi Gustav,
... that you absolutely don't run away from us icon_wink.gif.
Translated on 11-07-2026, 5:06.
Markus H.
Post18-01-2003, 13:36    Subject: Quote
Hi diesel.gustav,
I completely agree with Bertil: stay here!
Otherwise, I think that this forum is characterized by an enormous willingness to help (shared sorrow is half a sorrow icon_lol.gif).
Haehnle's thread here provides a compelling example of this.
@Christian Haehnlein:
Start a new topic and let's organize this mess first.
Translated on 11-07-2026, 5:07.
haehnlein
Post18-01-2003, 14:05    Subject: Quote
Markus H. wrote:
Ansonsten finde ich, daß sich dieses Forum ja eben durch eine enorme Hilfsbereitschaft (geteiltes Leid ist halbes Leid icon_lol.gif ) auszeichnet.
You are absolutely fantastic!!!!!!!! Thanks to your help, I have gone from being a practical mechanic to a TDI theorist (well, somewhat icon_redface.gif icon_redface.gif), and hopefully other readers as well icon_exclaim.gif icon_exclaim.gif icon_exclaim.gif icon_exclaim.gif icon_exclaim.gif icon_exclaim.gif icon_exclaim.gif.
Best regards, Christian icon_rolleyes.gif.
Translated on 11-07-2026, 5:08.
NVE
Post20-01-2003, 10:06    Subject: Quote
Hello everyone!
Although this thread is already quite full and my last post was a while ago, I wanted to briefly share my experience with you.
The problem was: difficulty starting the engine when it's cold, plus white smoke!
Troubleshooting: The injection timing was at 17°, which is far too early. After adjusting the pump using a multimeter on the fuel injector adjuster (2nd gear, full acceleration, 0.9-1.3 volts) and increasing the starting quantity, there are no more problems; it starts with one glow cycle. However, white smoke is still present during startup, although much less so and only for about 2 seconds. The engine also runs much smoother, but it doesn't pull quite as well in the higher RPM range.
The setup instructions using a multimeter are excellent and relatively quick to complete. Thanks to the authors!
Wolfgang.
'1994 Passat Variant with a 1Z engine.'
Translated on 11-07-2026, 5:09.
haehnlein
Post20-01-2003, 11:08    Subject: Quote
Here is the end icon_cry.gif.
That's where it continues icon_razz.gif.
Translated on 11-07-2026, 5:11.
This topic is locked, you cannot edit or reply. Third gear shifting/synchronization (resolved) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF not regenerating Troubleshooting & Guides
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Opel Astra G won't start - Troubleshooting. Diesel Engine Technology
No new posts Control units not responding, Audi A6 2.5 TDI (solved) On-Board Diagnostics (OBD)
No new posts VAGCOM Adapter 2.0: Problems and Issues Diesel Engine Technology
No new posts Oil pressure problem solved on 1z TDI! Diesel Engine Technology
