AEL: bei voller Volllast sporadisch Notlauf - Druckwandler? | Posts 16+
Go to page: Previous  1, 2
Henrik
Post17-06-2007, 19:48    Subject: Quote
Okay, great.
'I quote:'
- Rubber on the lower part of the intake manifold is torn. OK
- LD connection for LD control of the intake manifold detached or leaking OK
- The oil separator on the hose for the LD control system has come apart (plastic). OK
- LD solenoid valve defective OK - 25 Ohms - Hose of the LD control system damaged/torn/bitten OK
- Pressure vessel, loader/WG/loader in the bucket well, that's probably all that's left
Translated on 17-09-2026, 3:42.
Post17-06-2007, 20:30    Subject: Quote
Did you even look at the logs?
No icon_biggrin.gif.
LD Magnetic valve defective OK - 25 Ohms
Just because something is electrically okay doesn't mean it can't be mechanically broken.
You can test the turbocharger by connecting the connections at the solenoid valve in the appropriate way. Be careful, as the boost pressure can quickly rise, so perform the test drive with a light touch on the accelerator. If the target boost pressure is reached or exceeded, the turbocharger is working correctly.
Translated on 17-09-2026, 3:44.
Henrik
Post17-06-2007, 21:14    Subject: Quote
Okay, then I'll connect the cables (the top two?) and log the MWB 11.
I need to get some hose clamps from VW tomorrow.
Translated on 17-09-2026, 3:45.
Henrik
Post24-06-2007, 18:40    Subject: Quote
Hello!
I once installed some replacement chips.
Here's the boost pressure log with a diagram.
'viewtopic.php?p=111923#111923'
It actually looks quite reasonable, doesn't it?
No new posts ABS Light On: VW Transporter T4 Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8L, Golf 4 etc. - Turn signal relay is malfunctio... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 8E2 Wiper Problems: Fix Sticking Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8V 2.0 TDI: Intermittent 5V, Limp Mode Electrical Systems, Vehicle Electronics, Multimedia
No new posts VW Passat: Intermittent Limp Mode Issue Diesel Engine Technology
No new posts V6 TDI intermittently in limp mode, workshop wants to rep... Diesel Engine Technology
No new posts Engine Misfire with Working Climate Control Diesel Engine Technology
