TDI: GRA unlock issue - 90PS engine
cksIT
Post04-07-2007, 10:43    Subject: TDI: GRA unlock issue - 90PS engine Quote
I have a 1996 Alhambra with a 90hp TDI engine. The turn signal stalk has been replaced and seems to be working (you can see the reaction to inputs in diagnostic module 6).
I can't seem to activate the cruise control; the "Cruise Present" display still shows 0.0.
My A4 says 1.0...
I used code 11463, but nothing changed. The control unit is still the first generation, and the wiring harness was already pre-assembled (plug-and-play connector directly on the lever).
What could be the reason for that?
C. Seidel
Translated on 06-09-2026, 5:15.
Post04-07-2007, 12:57    Subject: TDI: GRA unlock issue - 90PS engine Quote
Does this thing actually work?
Because I believe I remember that 0.0 means "there" and 255.0 means "not connected".
Translated on 06-09-2026, 5:16.
cksIT
Post04-07-2007, 15:58    Subject: TDI: GRA unlock issue - 90PS engine Quote
I think I've found the problem. The bit for the clutch switch is set, and it doesn't change when the clutch is engaged.
In my Audi, the value of the set cruise control is 1.0, and the value of the unset cruise control is 0.0... therefore, I assumed that 0.0 also means "not set" for the Sharan icon_rolleyes.gif.
The problem should therefore be resolved by checking the clutch switch.
Translated on 06-09-2026, 5:17.
Post04-07-2007, 16:01    Subject: TDI: GRA unlock issue - 90PS engine Quote
http://www.jagiella.net/dirk/dirk.htm
-> car pages
-> Tips and tricks...
-> Installation of GRA...
There it is, the 0 and 255 stuff icon_smile.gif, just like I had it in my head.
Translated on 06-09-2026, 5:18.
vc
Post07-07-2007, 20:51    Subject: TDI: GRA unlock issue - 90PS engine Quote
Hallo, ich hatte auch mal ein ähnliches Problem, die GRA freizuschalten. Lösung: In einer der Freischaltanleitungen (hier aus dem Forum? - ich weiss es nicht mehr genau, will auch niemand zu nahe treten ) war ein Zahlendreher im angegebenen Freischaltcode, als z. B stand there.
11463 should actually be 11436. Maybe that's it. If not, please disregard everything and don't take it personally.
cksIT
Post08-07-2007, 0:21    Subject: TDI: GRA unlock issue - 90PS engine Quote
No, in this case, the activation seems to have worked.
It seems that only the clutch switch is defective, as it is constantly outputting a "1" regardless of the pedal position.
Unfortunately, I couldn't find a switch in the file.
Translated on 06-09-2026, 5:19.
No new posts Doku A3 8L, Airbag STG error cannot be cleared Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts The Electric Car - Why It Isn't Taking Off Technical Articles
No new posts A4 Doku: Engine Control Not Connecting to WFS. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts KData Scope: Unable to Activate/Unlock On-Board Diagnostics (OBD)
No new posts Injection start cannot be adjusted on the 1Z Upload
No new posts AFN Engine Control Unit: No Reprogramming On-Board Diagnostics (OBD)
No new posts Navigation CD cannot be ejected Electrical Systems, Vehicle Electronics, Multimedia
