Timing Belt: Replacement & Repair Guide (24-01-2003, 7:49)
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
Torsten
Post24-01-2003, 7:49    Subject: Timing Belt: Replacement & Repair Guide Quote
Can there be an increase in diesel consumption after a timing belt replacement? Car: Volkswagen Passat, 110 hp, engine code: AFN.
Where can I find the settings for using a multimeter with Ulf?
Thank you.
Translated on 28-08-2026, 8:54.
DocSnydor
Post24-01-2003, 8:08    Subject: Timing Belt: Replacement & Repair Guide Quote
Here!
goro
Post24-01-2003, 8:15    Subject: Timing Belt: Replacement & Repair Guide Quote
Can there be an increased diesel consumption after a timing belt replacement? Passat 110hp, engine code: AFN.
Thank you.
Hello Torsten,
Did you replace the timing belt yourself or at a workshop? As far as I know, the engine control unit needs to be checked and possibly reset after a timing belt replacement!
Best regards, Goro.
Translated on 28-08-2026, 8:55.
Michael II
Post24-01-2003, 8:17    Subject: Timing Belt: Replacement & Repair Guide Quote
before it once again becomes a major topic:
This has been discussed numerous times in the forum. Further information can also be found in the manuals, technical articles, and the error database.
Please use the search function before posting.
Tschüss
Michael II
Translated on 28-08-2026, 8:56.
Torsten
Post24-01-2003, 9:25    Subject: Timing Belt: Replacement & Repair Guide Quote
The ZR (rotor) was replaced in the workshop.
No new posts Documentary: Transporter 7D, Timing belt failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Issue: A3 (98+) - Not Centered on ESP Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt BLS Diesel Engine Technology
No new posts Timing Belt: Replacement & Repair Guide Diesel Engine Technology
No new posts Timing Belt BLB - Replacement & Cost Diesel Engine Technology
