hansemann2,5 Guest
23-01-2003, 21:17 Subject: Finally, it works! (Or: It's working!) |
A4 2.5 TDI, manufactured in 1998, with 120,000 km mileage.
So far: poor cold start, occasional power loss, oil leak, high fuel consumption.
Solution: New timing belt (the old one was stretched, causing incorrect injection timing), new glow plugs (5 were defective, 3 threads stripped when removing them), the crankcase ventilation filter was clogged, resulting in overpressure in the crankcase, and millimeter-thick layers of tar and oil were removed from the intake manifold.
I have deactivated the AGR system (using the vacuum hose).
Effect: Improved airflow in the lower RPM range, reduced turbo lag, resulting in sufficient power even below 1500 RPM, and hopefully better fuel economy (as I often drive at partial load, on Swiss highways, etc.).
Translated on 29-10-2026, 7:48.
haehnlein Schrauber
Joined: 08/22/2002 Posts: 877 Karma: +6 / -0 Location: Griesheim
24-01-2003, 0:21 Subject: Finally! It works as intended! |
hansemann2,5 wrote: | | 3 threads stripped out when unscrewing |
It happened to me too! How did you fix it?
Best regards, Christian.
Translated on 29-10-2026, 7:50.
hansemann2,5 Guest
25-01-2003, 23:10 Subject: Finally, it works! (Or: It's working!) |
I didn't make that myself.
The tap was thoroughly lubricated with grease, properly aligned, and carefully re-cut, and it's finished.
The next change is likely to cause bigger problems...
