ABS/ESP Light On: Troubleshooting Guide
shilliwhv
Post18-08-2007, 16:57    Subject: ABS/ESP Light On: Troubleshooting Guide Quote
Hello everyone,
"On my A4 1.9 TDI PD (AJM), the ESP and ABS warning lights repeatedly illuminate during acceleration (around 2500 RPM). There is also significant engine misfiring. After turning off the engine and restarting, the warning lights disappear again (and the problem can be reproduced repeatedly). The error code stored is 18074."
I replaced the glow plug about 6 weeks ago! The vehicle was running fine until yesterday! Yesterday, the problem started again!
Who can help me?
stefan
Translated on 27-10-2026, 21:37.
Ross-Tech-Support
Post18-08-2007, 18:07    Subject: ABS/ESP Light On: Troubleshooting Guide Quote
Replacing the PDE was never going to be successful because the AJM PD wiring is known to be faulty - so the solution lies there. icon_wink.gif
Translated on 27-10-2026, 21:38.
shilliwhv
Post19-08-2007, 15:00    Subject: ABS/ESP Light On: Troubleshooting Guide Quote
ok, but why did it then run for about 6 weeks without any problems? icon_confused.gif
I'll probably have to go back to my mechanic on Monday, whether I like it or not! Unfortunately, I don't have time to do it myself with a wrench. Does it make sense to replace the injectors when changing the fuel lines? (Mileage: 183,000 km)
Translated on 27-10-2026, 21:39.
Ross-Tech-Support
Post19-08-2007, 17:06    Subject: ABS/ESP Light On: Troubleshooting Guide Quote
If there's a fault in the cable harness or corrosion on the connectors, touching the PD (Power Distribution) unit during the replacement process will temporarily clear the issue. However, the corrosion will reoccur, and the problem will return.
...but it's important to remember that this is just a possible scenario, not a general one.
mserge
Post20-08-2007, 9:00    Subject: ABS/ESP Light On: Troubleshooting Guide Quote
I had a problem with the wiring harness on an AXR engine, but the ABS/ESP light was not illuminated.
Perhaps this can help...
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 27-10-2026, 21:40.
No new posts Parking Brake Light: Troubleshooting & Fixes On-Board Diagnostics (OBD)
No new posts Oil Pressure Light On? Check Oil Level & Sensor Diesel Engine Technology
No new posts Emissions Light On? Troubleshooting Guide Diesel Engine Technology
No new posts Engine Stalling? Check Oil Pressure Light. Diesel Engine Technology
