What happens if the check valve fails? AFN
Bastelfred
Karma: +6 / -4   Thank you, like it!
Post20-08-2007, 15:41    Subject: What happens if the check valve fails? AFN Quote
In my ongoing and unsuccessful search for the "Saugrohrdruck Regeldifferenz" problem, I have now discovered that a small check valve in the vacuum system is defective. It has a two-way opening. Anyone unfamiliar with it, it disconnects the pressure reservoir for the N75 on the turbo from the solenoid valve for the AGR. Could my problem be that the error code is being set under load and that it is going into safe mode?
So far, I have checked everything that I could find here as tips and that I could also check myself. So, everything from driving with VAG Com and observing data is done.
Okay, hier ist die Übersetzung:
So:
Values checked with VAG COM while the vehicle is stationary -> everything is as it should be
Magnetventil from VTG replaced with the one from AGR -> no change
MAP Sensor in MSG replaced -> No change
Defective parts from Turbo to Inlet Manifold -> Nothing found
VTG Adjustment checked for ease of operation -> feels smooth
All lines from the vacuum system replaced -> no changes, defective check valve found (has been ordered)
I'm afraid that's probably not the case, because there's nothing about it here.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post21-08-2007, 16:18    Subject: What happens if the check valve fails? AFN Translating...
[Translating...]
Naja, schreib doch mal wie sich der Ladedruck auf vollast verhällt.
zu niedrig, oder zu hoch, oder arge überschwinger.
Mag auch turbos geben ,wenn die richtig heiß werden, damit sich dann die VTG zwickt..
B.Eng (FH) u. KFZ Meister
Bastelfred
Post23-08-2007, 12:44    Subject: What happens if the check valve fails? AFN Translating...
[Translating...]
Ich werde mal die Tage versuchen eine Runde AB zu fahren mit Beifahrer der den Schleppi bedienen kann. Und ich werde nochmal versuchen alle "Druckwege" ab Turbo abzudrücken.
Das Problem mit dem Notlauf ist leider alles andere als selten, ich schaffe das in nicht mal 1 Minute inkl. losfahren wenn ich es drauf anlege. Will ich jemanden überholen schaffe ich es an ihm vorbei und dann gleich Notlauf. Um so mehr Last um so schneller geht das ganze. Auf der AB schaffe ich z.B. wenn ich über 140 Fahren will keine 300m ohne das er sofort wieder in den Notlauf geht. Gebe ich sachte Gas kommt es leider auch aber da dauert es minimal länger als bei fast Vollgas.
Ich weis ja nicht mal wie lange das Problem schon so extrem ist, weil in der Regel drehe ich den Motor nicht über 2000 1/min. oder halt maximal 2100 1/min wenn ich mal 100km/h fahre. Und da kommt das ganze ja nicht, ich glaube unter 3000 1/min war es noch nie aber bei allem darüber. Um so höher die Drehzahl um so schneller kommt es.
No new posts Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BLS - Erratic idle when AC is on - and more Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia I 1999 - Front wipers only work when it's dry General Tips
No new posts Ash mass - what happens if the DPF is full? Diesel Engine Technology
No new posts What exactly happens when G11 and G12 are mixed? Diesel Engine Technology
No new posts LMM Signal vs. Fixed Value: What Happens? Diesel Engine Technology
No new posts What happens at 2000 km? Diesel Engine Technology
