Reprogramming: Custom Messages for Each Model
Matthias87
Avatar-Matthias87
Post24-08-2007, 19:42    Subject: Reprogramming: Custom Messages for Each Model Quote
Hello.
I am currently looking for an original control unit (Steuergerät) for my ASZ vehicle. The device has the number 038 906 019 DQ.
Unfortunately, I couldn't find a matching control unit with that number, but I did find this one on eBay.
Can any engine control unit (ECU) be reprogrammed to work with a different vehicle or engine, as stated here? Or would it be better to avoid doing that and instead find an ECU with the correct part number for my vehicle?
Okay, here's the translation:
Thank you.
Matthias.
Upon my request, he responded with the following:
Hello Mr. Wagner,
We can provide you with exactly that.
You will receive from us an engine control unit (ECU) with the original factory software from Bosch/Seat, for the spare part number 038 906 019 DQ.
We have stored all original files for all brands, models, and control unit numbers.
You will receive a control unit that includes the original factory software as described above.
The control unit costs €149 plus €100 for reprogramming with the original Seat software 038 906 019 DQ.
So, you're getting the exact control unit you're looking for for just 249 euros. The same control unit would cost approximately 1000 euros from Seat.
If you are interested, please contact us as soon as possible, as we currently only have a limited number of 1.9 TDI PD engine control units (ECUs) available.
in stock.
MFG
Translated on 18-10-2026, 5:56.
mullemaus
Post24-08-2007, 21:45    Subject: Reprogramming: Custom Messages for Each Model Quote
You can reflash the control unit, yes. In some cases, it's even possible to swap different generations of WFS (Vehicle Software). However, the hardware must support it. You can't turn something very old into something brand new. icon_wink.gif
Translated on 18-10-2026, 5:59.
Rudi
Post25-08-2007, 7:40    Subject: Reprogramming: Custom Messages for Each Model Quote
'Jupp, and very old data versions (e.g., from some 85kW PD systems) are not compatible with the newer systems.'
STGs.
Besides that, the offer is outrageous. 150€ is quite a lot.
Charging 100€ to flash an original [device/software] is simply outrageous.
Rudi
Translated on 18-10-2026, 6:00.
Matthias87
Avatar-Matthias87
Post25-08-2007, 9:06    Subject: Reprogramming: Custom Messages for Each Model Quote
Okay, understood, thank you.
But a suitable part for the 96kw PD engine is somehow nowhere to be found! icon_sad.gif
No new posts Error code Climatronic 3B, model year 1999, 2000 model Troubleshooting & Guides
No new posts VAG VIN Decoder: Model, Year & Location Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Valve Compatibility: Do Valves Fit All Rims? Transmission, Chassis, Body & Interior
No new posts Reprogramming AFN MSG for 1Z On-Board Diagnostics (OBD)
No new posts Reprogramming the AGR control? Diesel Engine Technology
No new posts Reprogramming Audi A3 81kW AHF / Central Locking System Diesel Engine Technology
