Audi A6 Rear Door Handle - Replacement
Marr
Post26-08-2007, 10:51    Subject: Audi A6 Rear Door Handle - Replacement Quote
Hello there,
'I'm having a problem with my Audi A6 Avant 2.5 TDI, manufactured in 1999. The interior light in one of the rear doors isn't working, and the car's information system (FIS) doesn't register that the door is open. I've already removed the door panel and checked the microswitch, but that didn't solve the issue. Does anyone have any suggestions or the wiring diagram that I can use to continue troubleshooting?'
Best regards, Marr.
Translated on 15-10-2026, 7:46.
pax
Avatar-pax
2000 Volkswagen Passat
Post26-08-2007, 16:50    Subject: Audi A6 Rear Door Handle - Replacement Quote
Have you taken a look at the connector for the B-pillar?
Bye.
peace
Translated on 15-10-2026, 7:47.
Marr
Post29-08-2007, 6:50    Subject: Audi A6 Rear Door Handle - Replacement Quote
I checked the connectors to the door, but I didn't have any luck. Could someone tell me the exact pinout of the connectors so I can try measuring something?
'Marr' translates to 'angry' or 'annoyed' in English.
pax
Avatar-pax
Post29-08-2007, 7:17    Subject: Audi A6 Rear Door Handle - Replacement Quote
I once struggled with a similar problem on my Passat: https://community.dieselschrauber.org/en/viewtopic.php?t=15362&highlight=t%FCrsteuerger%E4t
A6 models and Passats from these production years should be at least similar, but my experience is based solely on the Passat. Nevertheless, the following steps are likely applicable:
* B-pillar connector - clean the contacts, check the cables for possible breaks (have you already done this?).
* Inspect the connectors at the door control unit.
* Door lock: disassemble and check the microswitches, inspect solder joints and circuit traces, measure the switch, measure the connection pins (you've already done some of this).
* Locate and expose the comfort control unit and check the connectors (this is located under the driver's seat in the Passat and is often damaged in cases of water ingress).
"If everything remains normal (i.e., no issues are found), the TSG (presumably a device) may be temporarily connected to the other door to see if the problem lies more in the control units or in the cable/connector pathway between them."
A diagnostic tool would likely be helpful to actually see the switch position as recognized by the control unit.
Unfortunately, I can't provide you with a wiring diagram for the A6.
Bye.
peace
Translated on 15-10-2026, 7:49.
No new posts Audi A4 B6 Rear Door Won't Unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T6, rear shock absorbers - replacement / weak performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Door Sensor for Interior Lighting Diesel Engine Technology
No new posts Fabia Tailgate/Door Sensor Replacement Transmission, Chassis, Body & Interior
No new posts AAZ: Preheating via Turbocharger Contact Diesel Engine Technology
No new posts Passat 3BG: Rear Door Unlock Problem? Transmission, Chassis, Body & Interior
