Oval Gear Spanner Element Belt
herold4
Karma: +4 / -1   Thank you, like it!
Post29-08-2007, 20:04    Subject: Oval Gear Spanner Element Belt Quote
Hello, I was wondering if anyone has a technical explanation for the "oval gear-sprocket chain"? I have read that this is a "Contitech" development and in the
Newer pump-nozzle engines are now available for use. Here, one writes that these belts {BELT_TYPE}
should be able to last up to 250,000 Km.
The function of the oval gear span element is still unclear to me, and I haven't found much information about it.
Can anyone help, maybe even a link?
tdi pumpe düse
Post29-08-2007, 20:33    Subject: Oval Gear Spanner Element Belt Quote
Here's something to read.
Ovales Zahnriemenrad.pdf
 File name:  Ovales Zahnriemenrad.pdf
 File size:  84.09 KB
 Downloaded:  1434 times
No new posts Documentary: Transporter 7D, Timing belt failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Issue: A3 (98+) - Not Centered on ESP Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BMR Expansion Joint: Types & Applications Diesel Engine Technology
No new posts Timing belt component, notched belt, broken. Cause? Diesel Engine Technology
No new posts Timing Belt: Replacement & Repair Guide Diesel Engine Technology
No new posts Timing Belt AJM Diesel Engine Technology
