VWGOLFIII Guest
21-01-2003, 20:11 Subject: Spritzversteller: Troubleshooting & Solutions |
Hello.
Is it possible to test an electric fuel injector cleaner on a 1997 Golf III, diesel engine (non-TDI), 1.9L engine code: AAZ?
If so, how do I do it? Can I use VAG-Com, or are there other options available?
Best regards from Mark.
Translated on 03-09-2026, 9:22.
diesel.gustav Guest
27-01-2003, 21:49 Subject: Alternative Solutions: Simple and Effective Options |
Deleted upon request.
Translated on 03-09-2026, 9:23.
VWGOLFIII Guest
28-01-2003, 9:18 Subject: Spritzgießen: Vorteile, Prozess & Anwendungen |
Hello.
I only want to test the fuel injector for functionality! It's necessary for my Elk car due to the Euro 2 emissions standard. Otherwise, my fuel pump is mechanical.
Best, Mark.
diesel.gustav Guest
30-01-2003, 23:05 Subject: You haven't said much yet! |
VWGOLFIII Guest
31-01-2003, 8:05 Subject: Spritzgießen: Vorteile, Prozess & Anwendungen |
Hi.
It turns out the problem was resolved. I took my car to Bosch and had the electric fuel injector control valve checked for functionality. I thought it might be the cause of the occasional jerking I've been experiencing, but it was actually the AGR valve.
Thank you, and best regards, Mark.
Translated on 03-09-2026, 9:24.
