ARL Motor: ab welcher Drehzahl beim anlassen startet er? | Posts 16+
Go to page: Previous  1, 2
Post24-08-2007, 15:16    Subject: Quote
yellow5 wrote:
Does anyone have any other suggestions for what I could watch
Disconnect the return hose from the fuel injection pump to the diesel filter and check if a visible stream of diesel fuel is coming out when the engine is cranked.
If not: Check fuel lines.
Translated on 05-10-2026, 18:41.
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post24-08-2007, 17:36    Subject: Quote
Have you checked with VAG Com to see if the WFS (Vehicle Speed Fluctuation System) is active? Do you have the original speedometer installed? Or is the immobilizer deactivated in the engine control unit?
Best regards.
Tom.
Audi SQ5 8R Cvub
Back to top Profile PM Email
yellow5
Post29-08-2007, 7:51    Subject: Quote
Okay, I disconnected the return fuel line and diesel is coming out.
How can I check with VAG-COM whether the WFS (Warm Function Start) is active?
It should normally no longer be active.
Translated on 05-10-2026, 18:42.
Jochen_145
Post30-08-2007, 14:38    Subject: Quote
..but because the exhaust manifold is not attached, it should start after a longer cranking period.
It smells strongly of diesel, but it doesn't actually do that.
It could be because the particulate filter (DPF) isn't actually regenerating, and the diesel fuel is just being circulated within the system.
So, as Matthias already mentioned, let's check the wiring of the PDE (Power Distribution Element) (power supply, connection cables at the MSG swapped, causing the PDE to close the bypass at the wrong time?).
Best regards, Jochen.
Translated on 05-10-2026, 18:43.
yellow5
Post01-09-2007, 20:55    Subject: Quote
Today, I (or we) got the ARL running.
I'm almost afraid to write about what it was related to http://www.smileygarden.de/smilie/Sonstige/icon_rofl.gif.
The inlet hose and the return hose were reversed.
The wiring was correct after all.
I just need to figure out why the gas pedal isn't working.
"Nevertheless, thank you very much for all the tips."
Best regards, Franz.
Translated on 05-10-2026, 18:44.
Post03-09-2007, 6:37    Subject: Quote
yellow5 wrote:
today, I (or we) got the ARL running.
Yes, yes: if attention wanes, the "devil is in the details" will mercilessly strike.
Still, it was nice of you to tell us what the cause was.
Translated on 05-10-2026, 18:45.
No new posts Engine temporarily maintains RPM, automatically increases... General Tips
No new posts Document: Audi A4, Engine not starting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 / Audi A3 BKC Engine Failure: Won't Start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Throttle Cut-Off: RPM Engagement Explained Diesel Engine Technology
No new posts C220 CDI: Rattling Noise on Startup Diesel Engine Technology
No new posts Golf V TDI 8V/16V: No DPF - Which Engine? Diesel Engine Technology
No new posts Engine Swap: R5 vs. V6 - Which is Best? Diesel Engine Technology
