Function of the L-line?
Post05-02-2003, 19:49    Subject: Function of the L-line? Quote
Hello everyone.
Based on my experiences from various experiments involving VAGCOM opto-adapters, I find it puzzling why Jeff Noxon directly connects the L-line to an optocoupler in his minimal adapter.
Depending on the optocoupler type, a 10 kΩ pull-up resistor might only allow for a slew rate of a very small amount to almost no volts per microsecond, and with a saturated optocoupler output (depending on the current sourcing capability of the COM port), signal delays of several microseconds could occur.
If the adapter still functions with vehicles that use the L-line (provided it is electrically compatible with the PC to some extent), this suggests that the L-line is significantly less demanding in terms of timing accuracy than the K-line.
This would mean that with my "Opto-Adapters," the transistor output stage for the L-line might be able to be omitted without compromising reliability.
"Does anyone know anything about the meaning/function and minimum requirements for signal quality of the L-line?"
Translated on 18-07-2026, 0:56.
hno2fe
Post05-02-2003, 23:22    Subject: Hello Ulf Quote
You don't need the L-line with the newer engine control units.
(Regarding triggering), more is not needed because the K-line, +12V, and ground connections are already sufficient.
Best regards, Olli.
Translated on 18-07-2026, 0:58.
DocSnydor
Post06-02-2003, 8:41    Subject: Function of the L-line? Quote
Hi, Ulf,
I also think that the L-line isn't really necessary.
I have a part from eBay (because I couldn't manage to solder a working adapter back then icon_redface.gif). In any case, the eBay part also doesn't have an L-line.
I can access the engine, ABS, and airbag control units in my 1994 Passat 1Z. However, for example, the central locking system doesn't work. I'm not sure if it even has a control unit... icon_question.gif
So far, I haven't experienced any errors, disconnections, or anything like that. However, unfortunately, I can't tell you what's inside because the 'manufacturer' filled the casing with hot glue icon_evil.gif.
Best regards.
David.
Translated on 18-07-2026, 1:00.
No new posts Needle Valve Actuator: Construction & Functionality Technical Articles
No new posts T5 Brake Fluid MIL: No Function Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2. K-line at the connector On-Board Diagnostics (OBD)
No new posts Connecting the second one. K-Line On-Board Diagnostics (OBD)
No new posts Knee Pain Relief: The K/L Scale Explained Diesel Engine Technology
No new posts VAGCOM: Troubleshooting Dual K-Line Issues Diesel Engine Technology
