RS4 Intercooler for A4 TDI
a4ever0815
Post05-02-2003, 21:27    Subject: RS4 Intercooler for A4 TDI Quote
Hello diesel mechanics,
Can anyone tell me if an intercooler from an RS4 will also fit into an A4 TDI (year 1996, engine code AFN)?
It would be very important because the old LLK is broken!
K.R.
Translated on 22-08-2026, 8:44.
Markus H.
Post05-02-2003, 23:17    Subject: RS4 Intercooler for A4 TDI Quote
Are you planning to make any further modifications to the engine?
If not, another LLK (likely referring to a specific type of product or treatment) probably won't make much difference.
There have been discussions about this before, when my troubled mind wasn't fooled by some lazy magic trick...
Ein großer LLK kann seine Kapazität erst bei mehr Ladedruck auspielen; mehr Ladedruck braucht auch mehr Einspritzmenge. USure, here's the translation:
'sw.' translates to 'southwest' in English.
Ultimately, more NM also requires more clutches icon_wink.gif.
Translated on 22-08-2026, 8:46.
a4ever0815
Post06-02-2003, 16:18    Subject: RS4 Intercooler for A4 TDI Quote
The engine has been chipped, increasing the power by approximately 40 horsepower. However, the fuel injection amount is a bit too high, which causes it to smoke when running at full throttle.
Therefore, the VNT-15 loader will soon be replaced by the VNT-17.
Since the water pump is already broken, I thought I might as well install a larger one while I'm at it.
Translated on 22-08-2026, 8:47.
Markus H.
Post06-02-2003, 17:49    Subject: RS4 Intercooler for A4 TDI Quote
Perhaps you should try a different linkage from a 2.5 V6 TDI – it was available on the standard A4 body style and should fit.
And it's likely to be even bigger than your current one.
However, there may be problems connecting the pressure pipes if they have a different format.
I can't say that with certainty.
Translated on 22-08-2026, 8:48.
No new posts Intercooler for Audi TT/A8 TDI 150 Diesel Engine Technology
This topic is locked, you cannot edit or reply. Oil in the air cooler Diesel Engine Technology
No new posts ASZ Pressure Hoses for Intercooler Diesel Engine Technology
No new posts Water Cooling for Intercoolers Diesel Engine Technology
