Golf 4 Alarm: Door Open Issue?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
jl_0815
Post22-10-2007, 17:11    Subject: Golf 4 Alarm: Door Open Issue? Quote
Hello.
I've been having a problem for a while now where my Golf doesn't seem to register when the passenger door is open.
So, when the door was opened, the interior lights didn't turn on.
But what's even worse is that if, after unlocking the car with the remote control, only the passenger door opens within the first 30 seconds.
Then he locked it again, and the alarm system went off.
For the past few days, my car hasn't been recognizing when the driver's door, passenger door, or trunk has been opened.
Now I'm wondering why he doesn't notice that the doors are open, but the alarm still goes off.
I haven't found a switch on the door frame. Is it possible to install one myself, or what kind of costs should I expect?
Thank you in advance.
JL
Translated on 31-08-2026, 4:42.
Post22-10-2007, 20:13    Subject: Golf 4 Alarm: Door Open Issue? Quote
The switches are located inside the door locks.
Do you perhaps have an ultrasonic interior monitoring system?
"He" then looks out through the open passenger door and notices that something is moving outside.
You can identify them by the button located at the very bottom of the left B-pillar.
Or you know what US sensors look like.
Translated on 31-08-2026, 4:43.
jl_0815
Post22-10-2007, 22:47    Subject: Golf 4 Alarm: Door Open Issue? Quote
First of all, thank you for the reply.
My Golf does not have an interior monitoring system.
So, am I understanding correctly that the door locks probably need to be replaced?
'How much will it cost approximately?'
Or perhaps someone else has an idea?
You're welcome... JL
Translated on 31-08-2026, 4:44.
vagtuning
Post22-10-2007, 22:59    Subject: Golf 4 Alarm: Door Open Issue? Quote
Front door locks with central locking: €108 each. Rear door locks: €103 each, including tax.
Translated on 31-08-2026, 4:45.
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Alarm System: What You Need to Know On-Board Diagnostics (OBD)
No new posts Power loss in TDI engine despite maximum speed Diesel Engine Technology
No new posts Error log entries despite normal function Electrical Systems, Vehicle Electronics, Multimedia
No new posts Vmax is still too low despite the new LMM? On-Board Diagnostics (OBD)
