Questions about replacing the driveshaft cuff on a G IV ASZ
Post08-11-2007, 13:38    Subject: Questions about replacing the driveshaft cuff on a G IV ASZ Quote
Saturday is the day: The outer boot of the driveshaft on the driver's side needs to be replaced again. The reason: a mounting error during the replacement under warranty in March 2004, during the first inspection. The boot is torn just before the small, inner clamp, probably due to too much tension icon_evil.gif.
Has anyone here ever replaced the cuff on a G IV ASZ? Is there anything special to be aware of icon_question.gif?
I have the original repair manual, but it mentions great things like a special tool for the large clamping bracket, which should be tightened to 25 Nm. Is it possible to achieve a good result without this tool? icon_question.gif
Okay, and how do you reliably mark the position of the 3 screws on the control arm icon_question.gif so that the geometry is correct afterward? A center punch might sound good at first, but it could cause rust...
And does the wave absolutely have to be completely removed, as Repfaden requires icon_question.gif? I was considering having the wave mounted on the drive side and only securing the outer end, so that the tripod joint is not overstressed.
Translated on 21-07-2026, 9:23.
Post08-11-2007, 19:43    Subject: Questions about replacing the driveshaft cuff on a G IV ASZ Quote
Unfortunately, I don't know the exact torque specifications; I always do it by feel. Removing the driveshaft? No, not in my case! Loosen the center screw while the tire is still mounted, remove the wheel, loosen the nut on the lower control arm (not the three small screws), remove the control arm and lower control arm together, then turn the steering wheel completely to the right, now remove the joint from the wheel bearing housing. Remove the damaged boot, use a 500g hammer to knock it out from the outside while holding the driveshaft in place. For the new boot, place the clamp on it and tighten it gently with pliers. I do this procedure on many vehicles without any problems! Note: When removing and reinstalling the joint, be careful not to damage the ABS sensor located in the wheel bearing housing.
Translated on 21-07-2026, 9:26.
Post08-11-2007, 21:14    Subject: Questions about replacing the driveshaft cuff on a G IV ASZ Quote
What is the reason you want to remove the ball joint or control arm?
At least with my AXR, I've never had to do that when changing the seals.
Are there any differences between the AXR and the ASZ?
And yes, the driveshaft needs to be completely removed. A safe and risk-free disassembly of a driveshaft (without damaging surrounding components) is only possible when it's already removed.
Translated on 21-07-2026, 9:27.
BM
Avatar-BM
Post08-11-2007, 21:24    Subject: Questions about replacing the driveshaft cuff on a G IV ASZ Quote
And yes, the driveshaft must be completely removed. A safe and risk-free disassembly of a driveshaft (without damage to surrounding components) is only possible when it is fully removed.
I completely agree. Furthermore, those few extra screws can be easily removed with the right tools in less than a minute, and then you can check and lubricate the internal joints if necessary.
3B5 AJM
Translated on 21-07-2026, 9:29.
Post08-11-2007, 22:13    Subject: Questions about replacing the driveshaft cuff on a G IV ASZ Quote
Oh yes, and how do you reliably mark the position of the 3 screws on the control arm so that the geometry is correct afterwards? A center punch sounds good at first, but it could cause rust...
Remove the wheel and mark the position of the ball joint at the bottom of the wheel bearing housing twice using a small flat-head chisel (90-degree offset).
For rust protection: Use a brush and black paint.
Translated on 21-07-2026, 9:30.
Post08-11-2007, 23:54    Subject: Questions about replacing the driveshaft cuff on a G IV ASZ Quote
@T3SurferViewing profile: T3Surfer:
"Thank you for your suggestions. However, I will follow the instructions in the manual and loosen the three screws on the wheel hub assembly and press the wheel hub assembly out. It's good to know that this can also be done with the clamp, and thank you for the tip about the ABS sensor! I have the torque specifications, as well as new screws for the wheel hub assembly and a new locking nut."
http://home.arcor.de/rgoebig/TDI/repfaden.jpg
@BertilViewing profile: Bertil:
No, you understood correctly. It also works at the ASZ, as usual, see above.
@BMViewing profile: BM:
Sure!
@Rainer:
Good tip about using a chisel!
Translated on 21-07-2026, 9:32.
Post09-11-2007, 0:12    Subject: Questions about replacing the driveshaft cuff on a G IV ASZ Quote
I do have one more question, though icon_smile.gif:
The Repfaden beetle has several external joints.
81 mm / 80 g fat / 40 g for injection / 40 g in capsule.
90 mm / 100g fat / 50g for injection into the joint / 50g in a package.
90 mm / 120 g fat / 80 g for injection into the joint / 40 g in a capsule.
98 mm / 120 g fat / 80g for injection into the joint / 40 g in a casing.
"Does anyone happen to know which type of joint is installed on the outside of the ASZ unit (I don't have the repair kit here yet)? I'm specifically interested in the amount of grease required, as even the two 90mm joints differ in that regard."
Or, to put it another way: The repair manual categorizes the outer joints based on the installed inner joints. Who knows which inner joints the ASZ has?
- Synchronicity
- Synchronous speed: 3700 RPM.
- Tripod AAR 2000
- Tripod AAR 2900
- Tripod AAR 3300i
Translated on 21-07-2026, 9:36.
BM
Avatar-BM
Post09-11-2007, 1:49    Subject: Questions about replacing the driveshaft cuff on a G IV ASZ Quote
Does anyone by chance know which joint is installed on the outside of the ASZ (I don't have the replacement kit here yet).
I would buy the cuffs icon_biggrin.gif this time as an exception. The fat pack is included in the set.
Cuff --> replaces 1J0 498 203A with 3B0 498 203E.
Mother --> 905 876 02
I have personally almost always had bad experiences with cufflinks from accessory brands.
3B5 AJM
Translated on 21-07-2026, 9:38.
Post09-11-2007, 8:27    Subject: Questions about replacing the driveshaft cuff on a G IV ASZ Quote
BM wrote:
Does anyone by chance know which joint is installed on the outside of the ASZ unit (I don't have the replacement kit here yet)?
I have personally almost always had bad experiences with cufflinks from accessories.
Hi there,
"I definitely wanted to get those parts from a reputable supplier (I have a nice mechanic in the family who is a NORA customer, and I'll be doing this job with him; he'll also provide a lift, pullers, etc.). We both only have limited time tomorrow (I'm moving), and the rear brake pads are due for replacement at the same time, so I wanted to clarify as many time-consuming details as possible in advance."
As far as I know, the replacement set always includes a 120g tube of grease, regardless of which joint it's for. That's why I wanted to know beforehand how much needs to be used. And what proportion should go into the joint itself, and what proportion into the casing?
But I think I'm approaching the topic a little too scientifically icon_lol.gif...
Translated on 21-07-2026, 9:41.
charlyfirpo
2013 Volkswagen Golf
Post09-11-2007, 17:22    Subject: Questions about replacing the driveshaft cuff on a G IV ASZ Quote
hello
"Well, it's not overly problematic. I just replaced all four on my car recently. As described in the repair manual, mark the three screws at the bottom and remove them. Then, pull out the entire wheel bearing carrier and rotate it to the side. Cut off the old boot and use a strong hammer blow to knock the joint loose."
In the case of this icon_razz.gif, the grease is a new type of seal that fits onto the shaft, a spacer ring, and another plastic ring.
Clean the joint as much as possible, then slide on the cuff and apply the included grease. Hammer the joint into place. It's important to tighten the rings properly. Otherwise, after a certain time, the grease may be pushed out by the tension rings. (I experienced this myself.)
I built something similar myself using an old pair of pliers, following a diagram from the repair manual. It worked relatively well.
Put everything back together and then it should work.
Best regards, Charly.
Golf 4 GTI TDI, ARL Serie 346031 Km
Webasto Thermo Top E
15.02.2013 -> Golf 6 GTD DSG CFGB/NLN, TT-V+T91R
21.03.2016 -> Golf 7 R, Limestonegrey, 19", Voll...
Translated on 21-07-2026, 9:44.
Post09-11-2007, 20:27    Subject: Questions about replacing the driveshaft cuff on a G IV ASZ Quote
Hello Charly,
Thank you for your description!
I was able to take a look at everything earlier. The car is already on the lift. As described, the repair kit contains everything. The clamps shouldn't be too much of a problem; in the original parts, they were simply pressed all the way down on the previously unrepaired side. I can manage that even without a torque wrench icon_wink.gif.
The screws are already marked, and the nut is removed. We'll start tomorrow morning at 7:00 AM icon_smile.gif. The control arm is quite smeared with grease; it will take some time to get everything clean.
Hopefully, we still have time to replace the rear brake pads (and hopefully there won't be any surprises like damaged seals or other issues on the caliper).
Translated on 21-07-2026, 9:46.
Post11-11-2007, 12:36    Subject: Questions about replacing the driveshaft cuff on a G IV ASZ Quote
Okay,
Now, here's the feedback. Everything went well icon_smile.gif.
One of the guide pins on a rear brake caliper was completely corroded, but we were able to repair it successfully.
However, when it comes to the procedure involving the foreskin, things can easily go wrong.
First tighten to 200 Nm, then loosen by half a turn, rotate the wheel 180 degrees, and then tighten to 50 Nm plus another 60 degrees.
Has anyone ever done that at a Volkswagen workshop?
Thanks again to everyone!
P.S.: My car loves the attention. After the second start following the repair, it displayed "Inspection in 3,000 km" icon_cool.gif.
Translated on 21-07-2026, 9:48.
joegolf
Post11-11-2007, 20:50    Subject: Questions about replacing the driveshaft cuff on a G IV ASZ Quote
Probably just as much as precisely weighing the fat in grams or tightening the clamps with a special tool, including a torque wrench. icon_lol.gif
Last Sunday, we replaced the front right axle boot on my car. It could have been done with common sense even without any prior experience...
Golf 7 GTI
Translated on 21-07-2026, 9:50.
Post11-11-2007, 21:18    Subject: Questions about replacing the driveshaft cuff on a G IV ASZ Quote
We couldn't close the clamp very much even with a large pair of pliers. Then I clamped the jaws of the pliers in the vice, which allowed me to close it a bit further. However, it didn't really go as far as it did on the other, original side of the vehicle...
How far were you able to push the large lever?
//edit:
And the question of the amount of grease didn't arise, because fortunately there was no visible dirt in the joint, and relatively little grease was lost due to the leak located far out. So, topping up the grease by eye seemed appropriate icon_wink.gif. Otherwise, I would have completely drained it and refilled it with the correct amount of grease. By the way, it was the 98mm joint.
Translated on 21-07-2026, 9:51.
joegolf
Post12-11-2007, 12:36    Subject: Questions about replacing the driveshaft cuff on a G IV ASZ Quote
Roger wrote:
We couldn't tighten the clamp very much even with a large pair of pliers. I then clamped the pliers in the vice with its head, which allowed us to tighten it a little further. However, we couldn't tighten it as much as it was on the other, original side of the vehicle...
It worked very well with a pair of pliers that had a small head but long handles (which provided significant leverage). The clamp is now securely fastened.
Golf 7 GTI
Translated on 21-07-2026, 9:53.
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts A few questions (I'm a diesel newbie) Questions about que... Diesel Engine Technology
No new posts LMM & Boost Gauge: Common Questions Answered Diesel Engine Technology
No new posts G4 Driveshaft: Replacement & Parts Transmission, Chassis, Body & Interior
No new posts Drive shaft removal Transmission, Chassis, Body & Interior
