ARL Improves Cold Start Performance
sinopdog
Post18-11-2007, 21:26    Subject: ARL Improves Cold Start Performance Quote
Hi.
I'm having a problem with my car (ARL - likely an engine code). It's been shaking again in cold weather. It only happens during the first five to ten minutes after a cold start, and then it goes away.
What I've noticed is that there's a slight bluish smoke coming out at the start, but it disappears later when the misfire goes away.
What could it be?
Do I have VAG-Com? Could I provide you with some data using it?
What do I need to log in with? I don't have much experience with this.
yusuf
Translated on 26-08-2026, 14:31.
Back to top Profile PM Email
ObenbeiMutti
Post22-11-2007, 10:51    Subject: ARL Improves Cold Start Performance Quote
I'm not an expert, but there could be many causes, for example, a faulty glow plug system.
For me, it was the same with the ARL (Abgasrückführung system), but only in the winter, and it had to be really cold. After deactivating the AGR, it disappeared!
Before you get in the car in the morning, just briefly check the hose.
Close the can, seal it, and write down whether it helped.
But be careful, the warning light is on, and the ABE (approval) might be invalid!
Translated on 26-08-2026, 14:32.
sinopdog
Post22-11-2007, 11:09    Subject: ARL Improves Cold Start Performance Quote
Hi.
Okay, I'll try it out in the next few days.
Glow plug system, ignition timing - all checked. OK.
Got it brand new last year.
-LMM
-AGR
Let's see, I'll post it later.
Translated on 26-08-2026, 14:33.
ObenbeiMutti
Post22-11-2007, 13:15    Subject: ARL Improves Cold Start Performance Quote
Okay, thank you, I'm looking forward to it.
It was also mentioned here that there is a special 'reduced-thickness gasket' for the EGR system icon_smile.gif specifically designed to address this type of symptom and resolve these issues.
You shouldn't have to live with the warning light permanently. Alternatively, it's possible to adjust the EGR rate via the OBD interface, but only within a minimal range.
This is only if the problem is truly narrowed down to this.
Translated on 26-08-2026, 14:34.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Golf 1J, from week 48/98, Clattering noise afte... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Lupo 6X1 MJ 2001, Clattering noises after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. 1Z TDI Shakes at 60-85 km/h Diesel Engine Technology
No new posts Draft Horse Shakes/Bucks Diesel Engine Technology
No new posts A3 8P 2.0 TDI: Engine Misfire at Idle On-Board Diagnostics (OBD)
No new posts Engine Misfire: Grey Smoke Explained Diesel Engine Technology
