SDI Fuel Injector: Performance & Reliability
Kopi
Post22-11-2007, 15:23    Subject: SDI Fuel Injector: Performance & Reliability Quote
Can a mechanical fuel injection pump from older VW engines be fitted to a 2004 SDI engine with 64 horsepower? I want to install it in my boat. I can't manage to use an electronic fuel injection pump with its control unit.
Best regards, Kopi.
Translated on 27-10-2026, 5:24.
Back to top Profile PM Email
mdonau
1988 Audi 80
Post22-11-2007, 17:48    Subject: SDI Fuel Injector: Performance & Reliability Quote
The old mechanical pumps are designed for swirl chamber engines and are not really suitable for [other types of engines].
suitable for a direct injection engine.
However, it is possible to install a fuel pump suitable for direct injection engines (e.g., VW LT with engine code ATA).
or combine the pressure component of an electric pump with a mechanical pump.
Best regards, Michael.
Passat 3B AFN Syncro, E46 330D, T3 1,7TDI, T3-Syncro TD
Kopi
Post22-11-2007, 20:31    Subject: SDI Injection Pump Quote
Thank you for the response.
It makes me really happy, because I've already done a lot of modifications to make the engine fit.
"Who would convert something like that, connecting it to a mechanical system and using a component from a VW LT? Are we talking about the 1.9L turbodiesel engine with around 74 horsepower?"
Translated on 27-10-2026, 5:25.
Post22-11-2007, 20:53    Subject: SDI Fuel Injector: Repair & Replacement Quote
Kopi wrote:
Who would convert something like that...?
Search on Google for "TDI Mechanisch" and the very first link is from Bernd Jäger (who was also active here before).
http://www.syncro-bernd-jaeger.de/DEUTSCH/TDI-Umbau/tdi-umbau.html
That might be something like what you're looking for... unfortunately, it's not exactly cheap icon_rolleyes.gif.
Keep us updated.
Translated on 27-10-2026, 5:26.
mdonau
1988 Audi 80
Post22-11-2007, 21:46    Subject: SDI Fuel Injector: Repair & Replacement Quote
Bertil wrote:
Search for "TDI Mechanisch" on Google, and the very first link is from Bernd Jäger (who was also active here before).
Yes, with the aforementioned pump from the 2.5L "ATA" engine, but with a turbocharger and everything else included.
It generally runs better in a boat at lower loads and speeds.
Perhaps a simpler, older 1.6-liter diesel engine would be more suitable?
What kind of boat is it, and how much power is required?
Translated on 27-10-2026, 5:28.
Kopi
Post23-11-2007, 16:48    Subject: SDI Injection Pump Quote
The boat is a motor catamaran with a Yanmar diesel outboard engine with 36 horsepower, which is not enough. 60 horsepower would be just right. Now I'm in the process of building my own outboard engine with a timing belt drive; there's no turning back, and some components are already finished. Is it possible to have a pump from an LT (presumably a specific model) adjusted to work with my engine, and would the connection to the housing fit?
Best regards, Kopi.
Translated on 27-10-2026, 5:29.
Kopi
Post23-11-2007, 16:59    Subject: SDI Fuel Injector: Performance & Reliability Quote
Bernd Jäger replied to me.
He wrote: "I have no idea about that."
Best regards, Kopi.
Translated on 27-10-2026, 5:30.
mdonau
1988 Audi 80
Post23-11-2007, 20:47    Subject: SDI Fuel Injector: Performance & Reliability Quote
The ATA pump is a direct fit, but it is designed for a turbocharged engine.
However, it should be adjustable so that excessive soot production can be avoided.
Alternatively, you could ask a pump repair specialist... maybe someone is looking for a way to earn some money.
Here in the north, the ones here would be :http://www.dieseltechnik-lindemann.de/index.html
possibly capable of building a pump...
Translated on 27-10-2026, 5:31.
Held467
Post23-11-2007, 20:52    Subject: SDI Fuel Injector: Performance & Reliability Quote
Hello.
"If necessary, an AAZ pump could be used as a temporary solution."
Dirk
Translated on 27-10-2026, 5:32.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts T4 Injection Pump Diesel Engine Technology
No new posts CAV Injection Pump Diesel Engine Technology
No new posts Fuel Injector AFN Diesel Engine Technology
No new posts Injection Pump 1Z - Buy Now! Diesel Engine Technology
