N75: Meaning and Explanation
Post17-12-2007, 16:24    Subject: N75: Meaning and Explanation Quote
Hi.
I'm currently keeping a close eye on my BMR (Base Metabolic Rate), and at the same time, I recommended a VAGCOM diagnostic tool to a friend who recently bought a used Audi A4 with a 130 hp engine.
Are our N75 components connected with different polarities?
Because my BMR is at 85% idle, which completely fills the VTG (Variable Turbine Geometry).
The A4 has a 19% idle speed - and I suspect that it's also fully open at that point.
Greetings.
Translated on 20-08-2026, 11:37.
Post17-12-2007, 19:09    Subject: N75 Valve: Meaning and Specifications Explained Quote
dieselmartin wrote:
Are our N75 units differently "polarized"?
I think it's just a software issue.
"In the pre-tax calculation sheet, the values in the 'LL' section are usually the highest. Conversely, the A4 (like most 1.9L VTG MSG models, as far as I know) inverts the TV signal at the diagnostic port."
Translated on 20-08-2026, 11:38.
Post17-12-2007, 20:13    Subject: N75: Meaning and Explanation Quote
Thank you, Ulf.
I thought it was probably just software.
I could only remember your idea about the "100-N75 in a graphic."
And that simply doesn't make sense for my tractor.
For me, a general rule is: More N75 valve opening -> more boost pressure.
Therefore, the question is...
Translated on 20-08-2026, 11:40.
Post17-12-2007, 20:24    Subject: N75: Meaning and Explanation Quote
dieselmartin wrote:
For me, a general rule is: More N75 -> More boost pressure.
Yep, your MSG outputs the boost pressure signal with the correct polarity.
Jochen_145
Post17-12-2007, 22:27    Subject: N75: Meaning and Explanation Quote
The Leon is outputting the TV signal inverted, which might be causing a brief moment of confusion. icon_confused.gif
Best regards, Jochen.
Translated on 20-08-2026, 11:41.
No new posts VAG-Com heisst jetzt VCDS ?! On-Board Diagnostics (OBD)
No new posts welches öl bei 2,5 tdi Diesel Engine Technology
No new posts Audi A4 8E 1,9 TDI AWX welches ZMS ? Diesel Engine Technology
No new posts What does "microencapsulated" mean? Diesel Engine Technology
