Differences between 2.0 TDI engines with 100kW and 103kW in the Touran
donalexo
Post20-12-2007, 13:22    Subject: Differences between 2.0 TDI engines with 100kW and 103kW in the Touran Quote
Hello everyone,
I'm considering buying a Touran. You can find the older models with the 100kW engine on the used car market.
What is the difference between the older 2.0 TDI engine and the 103 kW version?
Who else has the matching ICD codes ready?
Thank you for your help.
Alex.
Touran 1.9 TDI, EZ 09/2004
Post20-12-2007, 13:56    Subject: Differences between 2.0 TDI engines with 100kW and 103kW in the Touran Quote
Regarding the 103 kW generators, the question is whether they have a DPF (Diesel Particulate Filter) or not.
MIT DPF: 8-valve counterflow engine (bored-out 1.9L).
Without DPF: 16V cross-flow (likely newly developed).
Post20-12-2007, 14:27    Subject: Differences between 2.0 TDI engines with 100kW and 103kW in the Touran Quote
If I remember correctly, we had a similar issue with the same vehicle not long ago... I haven't looked into it myself, but maybe this will help.
Edit by guste: /viewtopic.php?t=16883&highlight=touran
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Headlight Leveling VW Touran 1T Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku VW Touran, GRA schaltet ab Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Unterschiede zwischen AHF und ALZ Diesel Engine Technology
No new posts 1Z vs. ALE: Key Differences Explained Diesel Engine Technology
No new posts Differences between AFN and AHF? Diesel Engine Technology
No new posts Unterschiede zwischen den Moduluhren (Standheizung) Transmission, Chassis, Body & Interior
