BKC Touran: Starting Issues, Starts on 2nd Try
haamerschlosser
Post03-01-2008, 20:50    Subject: BKC Touran: Starting Issues, Starts on 2nd Try Quote
Hello.
I am looking for a fault in a Touran manufactured in 2006 with a BKC engine.
The following problem is occurring: The engine starts and immediately shuts off, similar to the behavior of a faulty immobilizer. However, there are no error codes stored in the engine control unit (ECU) or immobilizer.
The throttle valve has already been temporarily replaced for testing purposes.
The fuel pump in the tank is new.
Turbo is okay.
Mass points and the starter motor speed are also okay.
The vehicle exhibits no handling deficiencies. The error occurs only sporadically, approximately once every 20 starts.
Does anyone have any ideas?
Hex-CAN USB Interface
Translated on 27-08-2026, 11:26.
servusssss
Post08-01-2008, 7:57    Subject: BKC Touran: Starting Issues, Starts on 2nd Try Quote
I had a similar problem with the engine starting.
It's a 2.0 TDI, but I think the starting procedure should be almost the same. The problem was the starter motor's speed. Therefore, the starter motor was replaced under warranty, but without success.
In the second step, the initial speed was adjusted, and now it's working.
"Sg" is an abbreviation for "singular." It is used to indicate that a noun or pronoun is in the singular form.
For example, the sentence "The cat is black" uses the singular noun "cat." The sentence "He is tall" uses the singular pronoun "he."
In German, the singular form of a noun is usually indicated by the article "der" or "die." For example, the singular form of the noun "Mann" (man) is "der Mann." The singular form of the noun "Frau" (woman) is "die Frau."
The singular form of a pronoun is usually indicated by the pronoun itself. For example, the singular form of the pronoun "ich" (I) is "ich." The singular form of the pronoun "du" (you) is "du."
Translated on 27-08-2026, 11:28.
No new posts Touran 1T: Fueling Problems & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Touran: GRA Disengagement Explained Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran 1T - does not start, No 15 terminal Diesel Engine Technology
No new posts SRA glued onto the Touran Transmission, Chassis, Body & Interior
No new posts Touran 2.0 TDI: Engine Stalling Problems Diesel Engine Technology
No new posts Touran: Change Service Interval - Easy Guide On-Board Diagnostics (OBD)
